Restraint Control Module blown... Ford want's a lot, now what? - Page 2 - MustangForums.com
Old 11-21-2011, 11:09 PM   #11
69MustangCoupe393cid
Cliffy, I just took a look through my hundreds of resistors and found a 2.2, 2.4 and 4.7 ohm. Would one of the 2.2 or 2.4 ohm ones work ok (to make things easier), or should I really put 2 4.7's together to get closer to that 2.3?
69MustangCoupe393cid is offline   Reply With Quote
Old 11-21-2011, 11:39 PM   #12
cliffyk
TECH SAVANT
cliffyk's Avatar
The stock spec for the squib is 2.3Ω, there is no tolerance specified. I think either the 2.2Ω or 2.4Ω would be OK though--if too low all they'll do is trigger the warning light because the RCM will think the squib(s) are bad.
It would not hurt the check them with a sufficiently accurate Ohmmeter just to be sure...
cliffyk is offline   Reply With Quote
Old 11-22-2011, 06:37 PM   #13
Will do. I'm going to try to take the car apart tomorrow if I can get off work early and maybe hit a junkyard this weekend, thanks again.
Old 11-23-2011, 04:02 PM   #14
Well I tested the resistors with a Fluke meter and they're all dead nuts on. They're the real deal, not radio shack so I'm not surprised. Should I bother putting the 4.7's together, or will the 2.2 or 2.4 work ok? If one of them works which one would be better to use?
Old 11-23-2011, 04:17 PM   #15
cliffyk
TECH SAVANT
cliffyk's Avatar
Quote:
They should be OK, with those values they have to be 1% or better components--rather rare actually. Purely from my perspective I'd use two 4.7Ω's in parallel and save the precision 2.2Ω and 2.4Ω resistors for when I really needed them--but then again I had to buy fifty 4.7's to get the two I needed.
So including the two I used when I got rid of the exploding steering wheel in my car, the two or three I've used in other projects, and the two I soldered together for the picture above, there should still be 43 or 44 left in the 1/4W resistor drawer.
If you are in no rush send me a "stamped self-addressed" envelope (PM me and I'll give you my address), one 1st Class stamp should do it, and I'll send you four of the 4.7s...
Old 11-23-2011, 09:05 PM   #16
Thanks Cliffy I appreciate that but I have some 4.7's of the same build quality as the others, so if I use them I'm sure they will be 2.35. You think that's best? I have more of the 2.2's and 2.4's than the 4.7's so I would rather save the 4.7's if I didn't have to use them. The resistors I have are GOLD GOLD I think that's less than 1%. I actually bought them off a fiber-optic company that was going out of business so they're the real deal for sure.
Old 11-23-2011, 09:48 PM   #17
Found the numbers on my box using a mirror. This thing doesn't look that hard to change, I don't know why people were telling me it was hard to get to unless I'm missing something. It's in plain sight, as well as the screws and electrical plug.
Link to my WTB ad with the numbers on my box.
http://mustangforums.com/forum/want-...ol-module.html
Old 11-23-2011, 09:55 PM   #18
Does anyone have the passenger airbag removal instructions or know where the bolts are? Driver side is easy enough, but I'm not sure about the passenger side.
Old 11-23-2011, 11:15 PM   #19
cliffyk
TECH SAVANT
cliffyk's Avatar
Use the 2.4's they will work fine--it really doesn't have to be that close and a bit too high is better than a bit too low--I suspect the squibs have a no better than +/- 10% tolerance.
If the colors are red red gold gold then they are 5% tolerance--it is a bit surprising they are that close to the marked value, however I have seen higher precision resistors marked as lower tolerance if the customer's specification cited that they "must be 5%" or whatever.
Old 11-23-2011, 11:23 PM   #20
cliffyk
TECH SAVANT
cliffyk's Avatar
Passenger side air bag RnR...
2002 Mustang GT Premium 5 Speed JonnyBlazeGT Mustangs For Sale 3 11-03-2015 02:10 AM
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
2013 GT500 GB/BS, 3,700K miles, All options except glass roof, 8yr/36k mile ESP inyadreems Mustangs For Sale 2 08-21-2015 10:10 AM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 11:13 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
04, 1995, 1997, 2003, 2004, control, ford, located, module, modulelocation, mustang, programed, rcm, restraint, restraints
