what kind of throttle bodies and plenums are yall running?
i have a cai and am looking to add a intake and plenum to complement the air flow. any adcive on brand names? what are yall running and have yall had any preformance improvement?
thanks guys
thanks guys
Trick Flow 75mm throttle body and plenum,:
http://www.americanmuscle.com/trickf...um-9604gt.html
With my review:
"Installation was straight forward, except my EGR (Exhaust gas return) valve was stuck on with a stripped bolt. When going WOT there is a noticeable gain in pickup (~10HP) but below 4000 RPMs the only benefit is the increased throttle response. Along with some of the other reviewers, I had to drill out the throttle cable slot on the new throttle body to get the throttle cable re-installed."
The 70mm would be effective as well, as long as you're not running FI.
With my review:
With my review:
With my review:
http://www.americanmuscle.com/sr-tb-70mm-9604gt.html
http://www.americanmuscle.com/sr-9604-plenum.html
I have a BBK 75mm- Trickflow plenum, got for 100 bucks used, I would rather have gears first.
I noticed a slight increase around 3800 (minimal) and it seemed to tighten up the cable or took 1/8th of an inch slack out which creates a stiffer gas pedal and quicker throttle response.
Cheers
Cheers
I've read the same things around here too, gears should be #1. If you get the gear/tuner combo from AM then that'll help when you finally upgrade the TB & plenum and you can change the tune.
Seems like you're coming up with a ton of questions I had the past few months, check out this group of threads if you haven't already:
https://mustangforums.com/forum/4-6l...ted-often.html
And look at this one (shout out to CliffyK) directly for your TB questions (basically, you only need to upgrade the plenum):
http://www.paladinmicro.com/?frm=AccufabFlow01.htm
What are your future plans for the car?
i have a list to have complete before may 2012.
ford 3.73 gears with tuner from AM ( going to get last so i can program all mods)
short shifter
headers
t/b and plenum
springs shocks struts
CC plates
maybe stage 1 cams and thats it.
all i have now is flows and a cai.
the car is my DD but plan on going to the track (1/4) after a few bolt ons.
i dont plan on a s/c but who knows, maybe in a few years
short shifter
headers
t/b and plenum
CC plates
short shifter
headers
t/b and plenum
CC plates
short shifter
headers
t/b and plenum
CC plates
- Short shifter - I've heard nothing but great things about MGW shifter, but I bought this one for $70 and I love it over the stock shifter: http://www.americanmuscle.com/t5-t45...stomer-reviews
- Headers - Most do the long tube headers (install is a pain) with a shorty H or X (more raspy) mid-pipe. Check out youtube videos or local meet ups where you can compare.
- After looking around, it's not much more for a coil over setup which is a MUCH better ride for a DD and adjustable which is great. Check out the maximum motorsport packages and search for any thread made by Jazzer, lol.
- CC Plates = http://www.americanmuscle.com/maximu...tes-94-04.html
- Should include FLSFC - http://www.americanmuscle.com/maximu...onnectors.html
- I dunno anything about Cams, lol. Maybe someday!
