No Cats Check Engine Light
Old 11-25-2011, 10:15 PM
Beastly GT
Beastly GT's Avatar
Default No Cats Check Engine Light
I have a 03 GT with a O/R xpipe, american thunder flowmasters, 75mm throttle body and a CAI. My check engine light is on because i don't have cats so i was wondering what the best way was to shut off the light. I also have MIL eliminators but they obviously aren't doing the job. Any advice would be awesome. Thanks
Beastly GT is offline
Old 11-25-2011, 10:52 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
get a tuner and turn them off...
sn95_331_GT_ yellow is offline
Old 11-26-2011, 12:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You can make your own MIL Eliminators, from feedback I have received these have worked on 99.44% of new-edge Mustangs...
cliffyk is offline
Old 11-27-2011, 12:40 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
I say programmer as well. What codes are you getting may not even be on because of the no cats. You should have I believe P0171 and P0174
PROMETHEUS PRIME is offline
Old 11-28-2011, 11:31 AM
Beastly GT
Beastly GT's Avatar
now after i have that done how do i connect it to the car?
Old 11-28-2011, 12:19 PM
MCxQubed
MCxQubed's Avatar
id get a tuner. you could check and clear codes, plus load tunes onto your car
MCxQubed is offline
Old 11-28-2011, 12:20 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
By cutting the O2 sensor signal and ground wires, and wiring in the MIL Eliminators as shown in this diagram (linked to on my "Make your own..." page)
Though many would gladly argue with me; the best way to make the connections is by using properly crimped butt connectors, filled with dielectric grease. This will beat the crap out of soldering which though not difficult does have a bit if "art" to it--also some O2 sensors use stainless steel wire which cannot be soft soldered--that's why Bosch specifies crimped connections for it's universal O2 sensors.
By properly crimped I mean using a die-compression crimper such as this one from Harbor Freight (often on sale for less than $10):
All other types of crimping tools are worthless, especially the ones from most hardware and home supply stores that just squash the connector into a flattened out mess.
Then tape over the butt connectors with electrical tape, or better yet use heat shrink tubing.
cliffyk is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: No Cats Check Engine Light
