S/C on a budget...
S/C on a budget...
Gents, I posted this info about a year ago. I'm doing it again mainly for the new members. Kerns talked me into it and helped me with my build (once again it's much appreciated). Before you guys think about buying the basic bolt on's you might want to give this a try. Believe me this can be done. I did it while deployed to Afghnastain. Took me 4 months but I got it done. Pls see below. It has the part, purchase price and where I bought it from. GL!
Vortech V1 T-Trim Head unit-700.00---- SVT Forums
Anderson Power Pipe--150.00---Corral.net
3.48 pulley--40.00---Corral.net
Tial Bov---220.00--JDsperformance
CX Rcing Intercooler (Complete kit)--210.00-- CX Racing (Ebay)
Seimens 42lb injectors--210.00--CorraL.net
HPX 05 Slot Maf--175.00--Kerns found this one for me..
Vortech mounting bracket--50.00-- Member of MF
Vortech mounting bracket hardware kit--95.00--superchargersonline
Oil Feed line--24.00--Vortech
Oil Feed Drain--24.00-- Vortech
SVT Fuel Pump-95.00-Member of MF
S/C belt--36.00---Summit Racing
NGK TR6 Plus--26.00---Auto Zone
Vortech Rib metal idler pulley ( 2.60", 6 rib)+Vortech 6 Rib Smooth Plastic Pulley (3"Lip)---85.00---JDsperformance
Stock Pulleys--30.00--- Corral.net
Total Cost: $2170.00
Didn't quite reach the $1500.00 Supercharger build but I think I did pretty good. Could have even been cheaper if I hadn't bought the Power Pipe, Tial Bov and went with smaller injectors. Any questions guys let me know..
Soldier GT
Soldier GT
Here is mine for comparison. This is before the HPX slot MAF and intercooler setup which puts about another $700 on top of this. You also have to remember your tune which bumps up the cost. Overall I think I am at a little under $4000 which is still not bad IMO.
Used Headunit V2 SQ 875.00 Used
39# Injectors 150.00 Used
GT fuel pump 150.00 New
90mm MAF 100.00 New
Bracket assembly 269.00 New
Discharge assembly 199.00 New
Air Intake assembly 215.00 New
Oil feed line 24.00 New
Oil drain line 24.00 New
3.6 Pulley 74.00 New
Pulley retainer assembly 12.00 New
NGK TR6 V plugs 16.00 New
75MM BBK TB/plenum used 200.00 Used
EV1 to EV6 adapters 29.00 New
AIT sensor 45.00 New
Oil and Filter 42.00 New
Tune 405.00
90mm MAF 100.00 New
Tune 405.00
I lucked out and found a V1 S trim kit complete and brand new for $2500 so the list is
V1 S trim $2500
instrumnt cluster pod $74
lightning maf $89
prosport boost/vac gauge $48
prosport fuel pressure gauge $49
Tune $400
spark plugs $20
6 qts Fresh oil $18
TOTAL $3198
plan on running MHS stage 1 blower cams sooner or later so that will be $595 cams+ $250 instal $175 retune so in the longrun by choice(blower cams) that will bring me up to $4218
V1 S trim $2500
lightning maf $89
Tune $400
spark plugs $20
6 qts Fresh oil $18
TOTAL $3198
Here is mine(this doesn't include other misc. stuff though like boost gauge/gauge pod/cut off wheels etc.
V1 S-Trim(Polished).................................... ..................$760(Ebay)
Intake/Discharge/Oil Feed/Oil Drain/Mounting Bracket..........$776(Superchargersonline)
42lb Injectors......................................... .....................$269(Buy Ford Racing)
SVT Focus Fuel Pump.............................................. ......$178(Kurgan Motorsports)
TR6 Plugs............................................. .......................$13(Advance Auto Parts)
MAFia Extender.......................................... ...................$160(Pro Dyno)
3/8 NPT Tap............................................... ..................$11(Carquest)
Punch............................................. ............................$8(Lowes)
Lightning MAF............................................... ................$85(Pro Dyno)
Screw in IAT Sensor............................................ ..........$18(Advance Auto Parts)
3/8 NPT Bung(For IAT Sensor).........................................$1 3(DIYAuto Tune)
Intercooler Kit............................................... ................$302(CXRacing)
Welding for BPV/BOV and other tubes on Intake...................$65(Local Shop)
Dyno Tune.............................................. ......................$400(Pro Dyno)
Total............................................. ..............................$3058
