Worth Installing 03 Mach1 intake manifold on 99GT? - MustangForums.com
Old 12-14-2011, 12:42 AM   #1
Slakkr183
Default Worth Installing 03 Mach1 intake manifold on 99GT?
I Searched and searched but i couldnt find anything on this, so if its an over asked question then i am sorry.. I have a 99GT 2v Windsor motor, and was wondering if Is worth swapping out my plastic PI intake for the 03 Mach1 Aluminum intake? or Any aluminum intake for that matter? i do have the stock heads with the 270ah cams, upgraded springs, 75mm tb/plenum, 80mm Maf, 24lb injectors, shorty headers, underdrive pulleys, and roller rockers. I Appreciate your input, Thank you.
Slakkr183 is offline   Reply With Quote
Old 12-14-2011, 07:08 AM   #2
ctgreddy
you dont see posts on this because it's not possible. none of the 4v intakes will work on the 2v heads. at your current level the stock intakes fine and you wont pick up enough power to justify the high costs of all the intakes. You might pick up 5-10 hp with a trickflow or bullitt intake, but those cost in around 700+.
ctgreddy is offline   Reply With Quote
Old 12-14-2011, 07:09 AM   #3
dwtjr3
With stock head mach one intake wont fit a 2v, honestly a intake isnt worth it until you have a built motor and some form of F/I to spin your car to 7k rpm, i dont have a intake yet still stocker
dwtjr3 is offline   Reply With Quote
Old 12-14-2011, 09:19 AM   #4
justinschmidt1
Yea, as others have said, its probably not worth it...and this is coming from someone that just spent 1k on a edelbrock victor JR setup.
justinschmidt1 is offline   Reply With Quote
Old 12-14-2011, 12:55 PM   #5
dwtjr3
Quote:
And justin got great results out of his intake, but thats because he has a blower, if your N/A its pointless
Old 12-14-2011, 01:28 PM   #6
justinschmidt1
Quote:
Even then, it really didnt start making more power till 4500 rpms and I have to rev the car well over 6k to really see the big gains.
Your better off saving for a used vortech or something
Old 12-16-2011, 02:59 AM   #7
Slakkr183
Thank You Everyone for the input, and good to know the 4v intake wont fit on the 2v heads. Thanks again.
Old 12-16-2011, 01:59 PM   #8
trailor
trailor's Avatar
now the bullitt has an aluminum intake that is more efficiently designed than a normal GT's, but the whole setup will cost you $1k+ depending on where you get it. not worth it IMO but many people have done it. you could net similar performance results with a bigger "upper plenum" and throttle body, and those should cost you less than $400 (got my combo new for right at $200). also note i said "similar," the bullitt intake will still have a better power curve. i'm strictly talking dyno numbers here.
trailor is offline   Reply With Quote
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
fix my problem steelers743 New Member Area 3 08-31-2015 08:16 AM
02' GT Convertible, Need help choosing intake manifold. Calizic 4.6L (1996-2004 Modular) Mustang 5 08-28-2015 02:46 PM
intake manifold gasket soulcaliber39 2005-2014 Mustangs 1 08-26-2015 04:26 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
03, 46, flow, fuel, gt, install, intake, jr, mach, mach1, manifold, mustang, rails, sale, victor
