Finally!!!
#21
#25
uber - I always thought xxx/50/15 were 26" tires?
also, my mickeys are starting to get cuts as my car squats real hard. I want to roll my fender lip this spring. Are you taking your car to someone or renting/buying the fender roller? I'm considering either buying it or I found a site to rent it...I wouldnt mind doing it myself
I run a 275/60/15 and these are 28's on a eibach pro kit setup:
#26
@ brent the 28x10.50 will hook goo but thats skinny for a 15x10 but will mount bu be really staggered, 15x8 would be optimal for that tire
@stanger metric tires are funny and the tire height isnt just decided bythe middle number but lile an equation between the first two i otta find my chart but a 325/50/15 does equal a 28 inch tire height im 99.9 percent sure. Just like. 275/60/15 is also a 28 just not as wide as the 325/50.
#28
Mine fit fine and im lowered but around corners and hard sqaut the inside of the fender lip rubs the tire just a hair, rolling the fender would solve the problem or just running stock height springs.
