advice on building motor please!!
Old 01-21-2012, 09:36 PM
  #21
yamahacurvejunky
yamahacurvejunky's Avatar
Also would I get any gains from going with roller rockers?
yamahacurvejunky is offline
Old 01-21-2012, 11:10 PM
  #22
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
you have a mod motor, not a pushrod...
we have followers, not rockers. the only option for us are Ford GT followers and unless youre building an 8000+ rpm motor they arent worth the money...
sn95_331_GT_ yellow is offline
Old 01-22-2012, 06:47 AM
  #23
97stanger
97stanger's Avatar
^ agreed, I would just buy oem stock followers if rebuilding the motor.
97stanger is offline
Old 01-22-2012, 06:07 PM
  #24
yamahacurvejunky
Ok so i think I have my final list ready to go:
MMR street rod 900 rotating assembly
Livernois stage 2 heads
Comp stage 2 cams
Kooks LT headers
T-56
SPEC 3+ clutch and flywheel
80# injectors
Lethal Performance returnless fuel system
Whipple 3.4L crusher kit
Ford Racing Diff and 3.73 gears
Moser 31 spline axles
missing anything major?
Old 01-22-2012, 07:35 PM
  #25
97stanger
97stanger's Avatar
arp hardware, a good oil pump, high-lift valvesprings, felpro gaskets and other hardware needed
Ever consider any sort of methanol injection?
Old 01-22-2012, 08:44 PM
  #26
yamahacurvejunky
Livernois says that valve springs are included with their heads.. I'm looking into the conversion to E85 but dont know what all I would have to change.
Old 01-23-2012, 05:25 AM
  #27
97stanger
97stanger's Avatar
you shouldnt have to change much. You will just need to confirm with Lethal that their system is compatible for E85, and you may POSSIBLY need bigger than 80# injectors
Old 01-23-2012, 05:30 PM
  #28
dwtjr3
dwtjr3's Avatar
Depending on how much boost i say you will need bigger injectors, I would say just get bigger ones to be safe since you can never have too much fuel and then you wont have to buy injectors 2 times. And it sounds like you are going to have a nasty car if you get the parts that are in your list. What numbers you shooting for?
dwtjr3 is offline
Old 01-23-2012, 06:59 PM
  #29
yamahacurvejunky
I'm aiming for at least 700hp. Its costing more than I expected to convert from 2V to 4V.
Old 01-23-2012, 07:54 PM
  #30
yamahacurvejunky
Is there a website you can find gas stations that sell methanol. I know there are 2 near me that sell E85.. also what concerns would I have running a meth system?
Quick Reply: advice on building motor please!!
