need help deciding what to do!
Good idea, well i think you should cam your current motor and see what it has with a 125 shot. And then you could just put some money towards your forged motor as you get it
You are better off just doing the work once. No reason to do the entire top end just to rip it back off and buy all new gaskets to put it on the built motor a few months later. I still say build the motor first. Especially if you have a trailer worst case scenario you snap an axle and trailer it home. I know the car is your DD so its much easier/cheaper to get a random 8.8 stock axle to put in to replace yours until you can afford to build it than it is to replace your motor.
camming this motor is no big deal i could have it done in a day. wont take long at all to get the vc's and timing cover off. I think i'm gonna go with that idea, since I have a few other things i need to do to the car before the trip anyways like subframes, new brakes, tie rod end, etc.
Was under the impression he was going to be doing all new gaskets... If he is just installing cams and doing nothing else then he won't have to rip the top end off twice.
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
