got some lumpy things in the mail!!!
Old 02-25-2012, 04:25 PM
  #21
01FPGT
01FPGT's Avatar
Originally Posted by ctgreddy
modified intake valves yes, specs are:
228/232 duration, 550/540 lift, 110/118 centerline, 114 lsa.
^ Man Can someone explain this to me ? just a quick short explanation. havent a grasp yet...thanks if not no big deal
01FPGT is offline
Old 02-25-2012, 04:59 PM
  #22
scooter3
scooter3's Avatar
Basically this:
DURATION
Duration refers to how long a valve is opened in relation to crankshaft rotation. This open valve time period is expressed in degrees of crankshaft rotation. So, a cam specification of 220 degrees duration simply means the cam holds the valve open for 220 degrees of crankshaft rotation.
As strange as this may sounds, more duration can be helpful in high RPM engines but not low RPM engines. The extra degrees of open valve time in high RPM engines gives the air flow a little more time to get into (or out of) the cylinder in spite of the piston's stroke. At lower RPMs, more duration can cause less power because the valves will be open at the wrong time in relation to the piston's stroke up or down in the cylinder. So, bigger numbers are not always better when it comes to engine performance parts.
CENTERLINE
The cam's centerline specification is used to tie the valve timing to the crankshaft's rotation. This spec is expressed as the number of degrees the crankshaft must rotate from top dead center until the cam has rotated to the peak (or centerline) of the lobe.
The centerline spec and the duration spec can be used to calculate when the valves open and close in relation to the crankshaft's rotation. When the valves open (or close) relative to the crankshaft's rotation is known as valve events or valve timing. Some cam manufacturers will provide valve event information and others only provide duration and centerline information. If your cam manufacturer doesn't provide valve event information, a software program such as Engine Shop can calculate this info for you.
Understanding the effects of valve events or valve timing is the real secret to understanding engine performance. For the engine to run at its peak performance, the valves must open and close at the correct time in relation to the piston's position and the crankshaft's speed. For more information on this subject see the Valve Timing & Performance page.
SEPARATION
Separation refers to the spacing between the intake lobe and exhaust lobe on the cam shaft. This spacing (or separation) is expressed in degrees on the cam, not on the crankshaft. So, a 108 lobe separation means the intake and exhaust lobes are 108 degrees apart from each other on the cam shaft.
This spec by itself really doesn't mean anything. If you hear someone else is using a cam with 108 separation, don't think that you should use cams that only have 108 separation!
Separation, just like centerline, is another way to tie the duration to the crankshaft rotation and end up with valve events. This spec is a little more complicated though, because it is in cam shaft degrees and the crankshaft rotates two degrees for each one degree of cam rotation. Also, if the cam has been installed either advanced or retarded, the valve events will be different. This is where the Engine Shop software can make your decisions easier because the software does all of the calculations for you and you don't have to guess at these confusing relationships.
LIFT
The final cam spec to understand is lift. While duration refers to how long the valve is opened, cam lift is used to determine how wide the valve is opened.
If the valves are not opened wide enough, they will cause a restriction for the air trying to enter or exit the cylinder. However, opening the valve past a certain point will not increase the flow to (or from) the cylinder. A good way to demonstrate this is with the garden hose in your back yard. When you first start to turn the water on, the flow increases but after a turn or so, opening the valve more has no effect on how fast the water comes out of the hose.
scooter3 is offline
Old 02-25-2012, 05:22 PM
  #23
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
beat me to it
sn95_331_GT_ yellow is offline
Old 02-25-2012, 06:46 PM
  #24
ctgreddy
ctgreddy's Avatar
that's a very good explanation scooter!
ctgreddy is offline
Old 02-26-2012, 04:21 PM
  #25
01FPGT
01FPGT's Avatar
your awesome! thanks for the explanation!
01FPGT is offline
Old 02-26-2012, 04:30 PM
  #26
MineralGrey
MineralGrey's Avatar
nice man im jealous Im going to sell my stealth fr500s to get me some cams :}
MineralGrey is offline
KingRando
10-02-2015 08:06 AM
RCS02v6
09-29-2015 01:46 PM
GLOCKer
09-28-2015 07:36 AM
treesloth
09-28-2015 07:03 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: got some lumpy things in the mail!!!
