Tremec Swap - Page 4 - MustangForums.com
Old 03-21-2012, 11:30 PM   #31
crash
BrandofPoop
crash's Avatar
Damn, good luck buddy, look at one of jazzer's sticky if you need any help, I think he did a write up on a 6 speed conversion.
crash is offline   Reply With Quote
Old 03-22-2012, 12:48 AM   #32
Bpohlman13
Bpohlman13's Avatar
I looked it over. Its the standard t56 he used. Im going to make a custom lower shifter boot and cover since the hole is about twice the size as before. I got the driveshaft in tonight. I just have to put the starter, x pipe, and foot pedal assembly and it should be completed. Do you guys think Ill be able to drive it without a tune for a manual? I am going to get it retuned, because I didnt get the best tune before, and I want to see what type of numbers Ill get with the manual conversion.
Bpohlman13 is offline   Reply With Quote
Old 03-24-2012, 02:59 AM   #33
Bpohlman13
Bpohlman13's Avatar
I have it running finally! All it needs is a proper tune to get rid of the fllashing OD light off and a leather shift boot. This transmission is SOOOOOOOOOOOOOOOOOOOOOOOOOOOOO smooth! Im just learning to drive stick. Which makes it hard since Im learning on a stage 3 clutch.
Old 03-24-2012, 02:39 PM   #34
crash
BrandofPoop
crash's Avatar
Quote:
Good **** bro, you'll be fine, I learned how to drive a manual in a 72' 240 z and a 69 Mach one, this should be cake
Old 03-27-2012, 01:14 AM   #35
Bpohlman13
Bpohlman13's Avatar
I got an appointment for friday to get it tuned! Im hoping to get a little more power out of it because it is manual and I didnt get the best tune before. Wish me luck!
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 06:54 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
03, 2010, 2012, conversion, gt, magnum, mustang, s197, sonic, swap, t56, tk0600, transmission, tremc, tremec
