Yet another Mark VIII swap thread
#41
For the coolant line,I would try and find one in a little better shape or take that one off and clean it up.Did you epoxy the holes in the IMRC's.Are you using the stock intake again or going with a cobra intake?Just wondering.I'm glad to see you're tearing it down and cleaning it up.Some guys would've just thrown it in as is.
#42
I am going back with the Mark VIII intake. I wish that I had a Cobra intake. I am trying to do this on as thin of a budget as possible. As for taking it apart, I had to take it apart to deal with the IMRC issue.
#44
I went back and re-read the four swap posts that I have bookmarked. It appears that no one has attempted to use the later model coil-over plug system that my Mark VIII engine came with. So then I will have to reuse the two front-engine-mounted coil packs that are currently on the '96 GT right? And then run earlier-style plug wires to the plugs right? If so, It's gonna look cheesy with later-model valve covers. I wish that there were a way to splice the later coil-over-plug system into the '96 GT wiring harness/computer.
#45
#46
There was a bunch of crap on the IMRC blades. Now here's the deal. I removed all of the spark plugs. All were not tight. Keep in mind that this engine set in a salvage yard for at least two years. The bottom of the intake had a soup of stale gas and what looked like oil. There were no stripped or blew out plugs but none were tight. It makes me think...hmmmm....
#47
Eh, I've seen worse as far as carbon build ups go. Try and smell the cylinders ? If they did spray a penetrating lube into the holes it was probably PB plaster which has a very distinct smell. Most penetrating oils will smell pretty strong. Ever consider pulling the oil pan a taking a look ?
#50
I have decided to use the COP system as they are used on the Mark VIII engine. A found a guy who makes a conversion harness. You plug the coil pack wiring connectors to this harness and it has connections to the coils in the correct locations. This will make things sooooo much easier.
