Yet another Mark VIII swap thread
Old 04-09-2012, 02:42 PM
  #51
CaptainRon
CaptainRon's Avatar
Originally Posted by Tesla_HV
I have decided to use the COP system as they are used on the Mark VIII engine. A found a guy who makes a conversion harness. You plug the coil pack wiring connectors to this harness and it has connections to the coils in the correct locations. This will make things sooooo much easier.
I like it
CaptainRon is offline
Old 04-11-2012, 01:10 PM
  #52
Tesla_HV
Tesla_HV's Avatar
I've been reading through a few other swap threads and I have some confusion about the oil pickup / oil pan compatibility. Will the '96 GT oil pickup work on the '98 Mark VIII engine?
Tesla_HV is offline
Old 04-11-2012, 05:22 PM
  #53
JC316
JC316's Avatar
Yes, it will.
JC316 is offline
Old 04-22-2012, 12:01 PM
  #54
Tesla_HV
Tesla_HV's Avatar
Putting JB Weld in the IMRC openings today. Good thing it is a crappy day outside because this is not something that you can just walk away from. It's been about a half hour and the semi-liquid mixture still wants to run out of the holes. I've cleaned up around the holes as much as I can without disturbing the patch area. Can you go back and clean this stuff up later?
Tesla_HV is offline
Old 04-22-2012, 12:39 PM
  #55
Bpohlman13
Bpohlman13's Avatar
Just get some 400 grit sand paper to clean it up.
Bpohlman13 is offline
Old 04-22-2012, 07:05 PM
  #56
uberstang1
Chupacabra
uberstang1's Avatar
Just an FYI, its only really necessary to fill the holes that would bleed into the closed casting/gasket areas, the ones directly between the ports don't need to be filled.
uberstang1 is offline
Old 04-22-2012, 07:16 PM
  #57
Tesla_HV
Tesla_HV's Avatar
I've now babysit these patches for about six hours. In the interim, I've read about the well-earned reputation of J-B the Weld glacial-flow drying time. Thanks for the information but I would think that the leak between cylinders would be counter-productive to the proper combustion process.
Tesla_HV is offline
Old 04-22-2012, 07:19 PM
  #58
uberstang1
Chupacabra
uberstang1's Avatar
There would be no leaks between cylinders as one square port and one round port= same cylinder.
Old 05-27-2012, 04:24 PM
  #59
corylee96gt
corylee96gt's Avatar
Hello, great job so far on your swap. I'm going to do the same swap on my 96 in two weeks, I found a complete 97 mark 8 motor with 101k miles for 550.00. Keep up the good work I'll be looking forward to seeing how yours turns out.
corylee96gt is offline
Old 05-27-2012, 09:33 PM
  #60
jeh4269
jeh4269's Avatar
Hey Keith we can add a new member to the 4v swap club.Welcome aboard.
jeh4269 is offline
Quick Reply: Yet another Mark VIII swap thread
