hydraulic throwout bearing
Old 03-10-2012, 03:21 PM
48prerunner
48prerunner's Avatar
Default hydraulic throwout bearing
Will the hydraulic throwout bearing from a 2005 and up mustang fit on the 3650 trans from a 2004 and down 3650? I want to put a 5 speed behind the mod motor in my 69 f-100 and the 2005 and up shifter position is not the greatest.
48prerunner is offline
Old 03-10-2012, 03:29 PM
FlamingoGT
FlamingoGT's Avatar
I thought the 05+ had remote shifters, or was that something to do with the automatics in those?
Other than that, I also thought the 3650 was a 3650. In other words, that would work as long as you had the other stuff to go with it (ie hydraulic plumbing etc).
FlamingoGT is offline
Old 07-11-2012, 02:53 PM
48prerunner
Well going cable clutch now with a t-45.
Old 07-12-2012, 11:44 AM
smitty2919
smitty2919's Avatar
Mcleod makes a hydraulic system for the 99-04 mustangs. About $700. But that's not to say it will work prefectly. I don't know the length of the lines, so you may be able to buy the main components then custom make the lines to fit your application.
smitty2919 is offline
Old 07-14-2012, 11:30 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It is a "remote" monkey-motion shifter in that it mounts externally to the transmission--still mechanical:
As opposed to the "turret mounted" shifter on our cars:
This is a separate issue from the hydraulic clutch actuation...
cliffyk is offline
6bangr
02-15-2016 07:40 AM
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
Mikett
09-12-2015 10:52 PM
Quick Reply: hydraulic throwout bearing
