Car problem after tune HELP
Old 03-14-2012, 07:45 PM
Lowandslow2v
Lowandslow2v's Avatar
Default Car problem after tune HELP
So I tune today and tune went perfect car dumped at 509rwhp and 446hp. On the way home from the shop car drove perfect. After traveling for about 1hr and 30min car was running great. Getting near my exit I punched it in 2nd to feel a pull car pulled awesome but 5min after that car started stalling and it turned off on me.
I turn the car on and it starts up but idles for about 5 seconds then it shuts off, any idea why this is happening?
Lowandslow2v is offline
Old 03-14-2012, 07:49 PM
MCxQubed
MCxQubed's Avatar
You have a wideband or any gauges that are showing anything out of the ordinary?
MCxQubed is offline
Old 03-14-2012, 07:53 PM
Kerns
Kerns's Avatar
Try disconnecting your MAF see if it idles.
Kerns is offline
Old 03-14-2012, 08:05 PM
Lowandslow2v
Checked all ground cables all sensors and fuses and there all good
Old 03-14-2012, 08:06 PM
Lowandslow2v
Boost gauge reads fine and the a/f gauge reads fine for the 5seconds that it's on and ima try disconnecting the MAF but it has a mafia on it
Old 03-14-2012, 08:42 PM
Lowandslow2v
Could it be spark plugs causing it to turn off?
Old 03-14-2012, 09:28 PM
Kerns
Kerns's Avatar
Most likely wouldn't allow it to start in the first place if it was spark plugs. Like I said, disconnect the MAF and try and start the car. Let me know what happens.
Kerns is offline
Old 03-14-2012, 09:49 PM
ctgreddy
ctgreddy's Avatar
that's not gonna be spark plugs. Gotta be some sort of sensor. Did they put a chip in it? If so maybe they didn't clean off the pcm well enough where you connect the chip at, if there's still **** on there it could easily get "disconnected" randomly which would cause it to stall.
ctgreddy is offline
Old 03-14-2012, 11:28 PM
Lowandslow2v
Kerm I'm going to try the MAF sensor and let you know but why would you think it's that? And no they didn't chip it he wrote the tune downloaded it to my diablo sport then downloaded it to the car
Old 03-15-2012, 06:01 AM
ctgreddy
ctgreddy's Avatar
do you have the option of downloading a different tune back onto your car while saving the one he made you? that way you can try a different tune just to see if that could be it.
ctgreddy is offline
Quick Reply: Car problem after tune HELP
