Weight reduction suspension
Old 03-19-2012, 01:20 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Originally Posted by scott4.6
Id pay a $1000 for 3 tenths anyday. 3 tenths you will feel that for sure.
3 tenths in weight reduction alone is worthless unless it's strictly a track car. I wouldn't pay money to strip my car down.
WannaBeGearHead is offline
Old 03-19-2012, 01:28 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
^^^^To each his own my friend.
We all have different goals for our cars, and weight is the enemy of anything performance related. Less weight stops, turns and accelerates better.
As mentioned above, many guys have spent more than $1000 for less than 0.3 off their ET.
I'm slightly skeptical about losing 350lbs for $1000, but I'm sure he could get 250+. That is unless he plans to remove stuff like AC.
TRUEBLUE3934 is offline
Old 03-19-2012, 05:04 PM
ddmsgtr1
ddmsgtr1's Avatar
I'll be removing the ac, only because i have a truck to drive around everyday now instead of the mustang. And once again that comes to ballast. You dont want to tear all the weight out of the rear of the car and have everything sitting in the front still.
ddmsgtr1 is offline
Old 03-19-2012, 07:06 PM
WannaBeGearHead
Go Texas!!!
I understand that but from what I've heard from guys who strip down their cars they don't enjoy driving it as much afterwards. If it's a DD or a car you cruise around in a lot I wouldn't do it. Purely track then I have no issues.
Old 03-20-2012, 01:17 PM
steven121
steven121's Avatar
Guys calm down 1k was just a quote for buying everything brand new here's the list with research as well.
Spare tire - 26.4
Jack and crow bar - 6.6
Trunk pad - 6.0
Mott bar under diff - 7.8
Rear seat delete - 47.2
Longtube vs stock -10
Odesy battery - 22.2
Upr k member - 65.00
Front passenger - 43.0
Driver seat - 48.0
Ac delete - 30.0
Magnaflow xpipe - 22.4
Upr a arms - 4.5
Tokico shocks - 7.0
Should equal around 379.1 from my adding.
Now include the following rear seat delete kit + 10.0
Driver side racing seat +10.0
Passenger seat + 10.00
If I got most of this stuff used it would be less than 1k and the seats would be cheap knock offs to do the job compared to sparco
steven121 is offline
Old 03-20-2012, 01:20 PM
steven121
steven121's Avatar
Also add in -40 lbs found some rims that are 10lbs minus stock after doing the math your total weight dropped is 386.1 add in your 30 lbs gives you 356.1 total weight off your car making my cobra weigh a grand total of 3104 lbs
Old 03-20-2012, 01:28 PM
WannaBeGearHead
Go Texas!!!
What other mods have you done? Is your car a DD/drag/autox?
Old 03-20-2012, 02:54 PM
steven121
steven121's Avatar
This car will be my dd it helps with the gas a bit and I will be putting a procharger on it the power to weight ratio will be good
I have a July ram air, 4.10 gears, oil to air seperator, short shift, flow master exhaust, bumpsteer kit and transmission brace
Old 03-20-2012, 03:22 PM
WhiteFaleen2001
WhiteFaleen2001's Avatar
to save you time for other weight questions:
http://www.modularrevolutiontech.com/Weight.htm
and
http://mustangboards.com/drag-racing...tion-list.html
WhiteFaleen2001 is offline
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Weight reduction suspension
