New Clutch question - MustangForums.com
Old 03-21-2012, 12:12 PM   #1
Repzard
Repzard's Avatar
Default New Clutch question
I read that a new clutch should be broken in for about 500 miles of stop and go normal driving.
My question is it bad to do long highway drives on a clutch that hasnt been broken in yet ?
Would highway driving cause more heat or damage new clutch that hasnt seen 500 miles yet.
BTW..Only has 12 miles on it as of now
Thank You Mfers
Repzard
Repzard is offline   Reply With Quote
Old 03-21-2012, 02:05 PM   #2
kj4kym
You should be fine with highway driving. Break in period means no dumping the clutch at 5 grand and no speed shifting. Take an easy day trip somewhere
kj4kym is offline   Reply With Quote
Old 03-21-2012, 02:27 PM   #3
Moonshine
Moonshine's Avatar
What did you put in it repz?
Moonshine is offline   Reply With Quote
Old 03-21-2012, 05:29 PM   #4
Repzard
Repzard's Avatar
Quote:
I put in a King Cobra from UPR .
FRPP Billet Steel FW
New FRPP fork and stock pivot ball.
Replaced TB and Pilot bearing (did bread trick to remove pilot bearing) ***king worked
Replaced all hardware (FRPP FW bolts (8) and pressure plate bolts(6) and 3 pins)
New Tranny fluid Mobile 1 full syn atf .
Clutch and Pro 5.0 shifter is like butter now,So damn smooth
Seem to grab like a SOB too.
took about 2 days off and on but can be done in a day,very easy job in these cars if you have a lift to use and a tranny jack.
Couldnt be happier Moon,like a new PONY\Snake
Cant wait till its broken in so I can go to the track and get some numbers this year.
Hoping for a 13.6-13.8
Old 03-21-2012, 06:16 PM   #5
Kerns
Kerns's Avatar
Just keep in mind that 500 miles of break in time needs to be done around town so that you are having to constantly shift and go from a stop to help break in the clutch. If you do 500 miles of highway driving it doesn't help break in the clutch.
Kerns is offline   Reply With Quote
Old 03-21-2012, 07:55 PM   #6
Repzard
Repzard's Avatar
Quote:
Very understandable Kerns
2005 Mustang - Transmission rattle and slippage/stuttering AmericanMuscle4.6GT 2005-2014 Mustangs 7 11-10-2015 03:06 PM
Time for a new clutch? MasterLanMan 4.6L (1996-2004 Modular) Mustang 6 09-13-2015 09:21 PM
Huge Savings from Lethal Performance.com!(Whipple, McLeod, Kooks, & MUCH MORE..) Boostaddict Lethal Performance 2 09-08-2015 10:56 PM
HELP.. Should I buy this fox? raleigh05GTO New Member Area 5 09-04-2015 08:09 AM
500, 97, 99, bad, break, city, clutch, cobra, driving, highway, miles, mustang, noise, period, t56
