i run pretty much the same ones except the jegs version .
Diameter & Width: 15 x 8"
Bolts & Bolt Circle: 5-4.5"
Back Spacing: 5.5"
also im running a 275 -50-15 MT drag radial
Back Spacing: 5.5"
I take it Machs will be the same size bolt circle and back spacing and all
It will all be the same. Exactly what my1stgt posted is probably what 90% of the guys out there are running...depending on your setup you may benefit from a 28" tire aka 275/60/15 but would need more info on your setup
Setup as in...? I have 4.10's, tokico dspecs, jlt ram air, couple other nick nacks here and there
