HID problems...
Old 04-02-2012, 05:59 PM
mustangmancp
mustangmancp's Avatar
Default HID problems...
Ok so I've had these HIDs in my car for about a year now and have been having issues with them since i put em in and I'm just now getting tired of it lol.
1. When I flip my "brights" on it's my dims and vis versa...not really a problem just kinda annoying.
2. When I turn my headlights on sometimes the drivers side headlight doesn't come on, but after turning it on and off like twice it will come on? What could that be realated to?
Any input would be great...my dad's got my car at home while I'm at school and wants to get to work on it so I told him you guys could help me out!
Thanks boys!
mustangmancp is offline
Old 04-02-2012, 06:22 PM
Aereon
Aereon's Avatar
Don't understand this question, if the headlights are dimming then it may be the ballasts since they regulate/convert current for the bulbs. If interior dome lights/dash lights are dimming you may be running a cheap kit thats drawing too much power through the lines to activate the magnet or the second bulb depending on how your high beams are setup.
Possibly bad/failing igniter and or loose wires.
Aereon is offline
Old 04-02-2012, 06:23 PM
jtb727
jtb727's Avatar
With the Hi beams/low Beams I can't say.. Mine are just on.
But with the driver side not wanting to fire up, mine used to do it too.. go through check your grounds, and plugs.. mine turned out to be a plug that didnt completely "snap" over the little nipple, because the nipple allowed the fingers of the plug to slide upwards and become loose. So I had to do some massaging on the fingers with a pair of dikes to it would stay nice and tight.
jtb727 is offline
Old 04-02-2012, 06:26 PM
mustangmancp
In the first question what I'm meaning is that when i flip my brights on and it shows it on my dash, its my dims, and when I turn my brights off, it goes to my high beams. Its like they're flip flopped.
Old 04-02-2012, 06:56 PM
Aereon
Aereon's Avatar
thats because they are flip flopped, the kit you have is an international kit, the wires for your low beam and high beam will need to be swapped. Swap the two power wires on the blue plug and that should fix that issue.
For the flickering/not firing light, #2 still applies.
Aereon is offline
Old 04-02-2012, 07:37 PM
StockD15b
StockD15b's Avatar
^This +
get a relay harness.
StockD15b is offline
Diode Dynamics
28
05-26-2022 12:02 PM
kawiguy827
09-22-2015 10:52 AM
Mobiusone stang
09-07-2015 08:46 PM
inyadreems
08-21-2015 09:10 AM
stangmods.com
121
03-09-2009 01:18 PM
Quick Reply: HID problems...
