Questions about replacing my almost blown 3650
Old 04-09-2012, 07:12 PM
evanjp
evanjp's Avatar
Default Questions about replacing my almost blown 3650
My 3rd gear synchro has been blown for the past year and yesterday, even with rev-matching to slip it into third, it's popping out of gear. At the same time, it's become a chore to even put it in gear in any gear. 2nd is clunky, 4th grinded a couple times, and the shifter barely feels like its in neutral because when moving the shifter right and left I can feel the gates. When pushing the clutch in, the shifter moves and vice versa.
I realize it's most likely beyond repair, so I've been trying to figure out what route to take in getting a new transmission. From meineke, they said they could find a re-manned unit for between 12-1800 bucks. On ebay there are the same things for 800-1200. A used one from prestige mustang in Georgia is 700. The guy Todd at prestige says they have a 90 day warranty. He says that if there's any slight problem they dot sell it as a transmission but as a core.
Bottom line to where I'm trying to take this is should I trust a 700 dollar transmission from prestige mustang off eBay or go the safer route with a re manufactured unit for the 1200-1800 dollars? Or the remanned 800-1200?
What is the best route and does anyone have any pointers or advice?
evanjp is offline
Old 04-10-2012, 07:48 AM
TRUEBLUE3934
TRUEBLUE3934's Avatar
I guess budget is the factor.
If you can afford to spend a bit more, I would go with the unit that comes with a good warranty. Another thought is how long you plan to keep the car and what other plans you may have for it? If you will keep it a long time and like to drive it in a spirited fashion, you might want to get a trans that has been rebuilt with some more robust syncros, etc.
Bottom line... you usually get what you pay for. A cheap replacement is cheaper for a reason. I would get the best trans that you can afford.
GOOD LUCK!!!
TRUEBLUE3934 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
CarrieS
09-01-2015 01:00 PM
Calizic
08-28-2015 01:46 PM
daytooday
08-16-2015 08:22 AM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Questions about replacing my almost blown 3650
