First add on!
yes rain has an 09, but purp is saying that a cai is useless for our cars, but it is useful for s197's. So he's asking why rain recommended it
Cliffyk is referring to GT24 (the OP) with the 04. Isnt that who this thread is about? Or did I lose track?
Gears would be a good idea. Is this a daily-driver, street-only, street/track, or track-only vehicle? (if track, what kind? drag? autocross? etc.)
Like I said I think I wasnt being too clear. I dont know if this helps you guys see where I coming from.
I was indeed referring to the OP, don't know why the '09 guy is giving advice in the '99 to '04 forum?
Anyway, here is my usual 2¢ worth re: "first mods":
First steps, in this order:
Parasitic load and rotational inertia reducing things like underdrive pulleys, aluminum drive shafts and lightened flywheels will not make palpable differences except under hard acceleration in the lower gears.
Long tube headers will make unmistakable improvement, however how a particular design affects the powerband should be studied. Those that provide the greatest peak HP gains may leave you with a car that is a bit doggy unless you always drive it like you just stole it. Keep in mind also that with most LT headers one or both will have to be removed to pull the transmission.
That said, now that I am retired and my '03 is no longer a true DD (I have put fewer than 400 miles on it since the beginning of the year) LT's are moving up my "to-do" list...
- Open up the exhaust, 2-1/2" from the manifolds back;
Catted or not (it doesn't really matter from a power gain perspective) H- or X-pipe (an X will perform better at high rpms, however sound is the predominate difference with H-pipe = musclecar, X-pipe = NASCAR).
- Buy a tuner and load a premium fuel tune;
The stock tune is very poor, with milquetoast spark advance, and going pig-rich at WOT especially with the '03 and '04 MY engines having the lavender 21 lb/h injectors;
- Then rear-end gears (use the tuner to fix the speedometer);
3.73:1 and 4.10:1 are the most used choices. If you do a lot of highway driving (20+ miles a day) both will reduce fuel economy. But the good news is that a custom tune will increase fuel economy and take up most of the loss from 3.73s, and a lessen the loss from running 4.10s.
jwog666
12-27-2021 08:09 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
