HOW DO I GET TO THE 12'S IN THE 1/4? - Page 3 - MustangForums.com
Old 04-22-2012, 09:30 AM   #21
boduke0220
This was with longtubes, intake, 4.10s, subframes. And LCAs. Roughly a 12.6 1/4 pass
http://www.youtube.com/watch?v=vlXmt...e_gdata_player
boduke0220 is offline   Reply With Quote
Old 04-22-2012, 04:23 PM   #22
TRUEBLUE3934
"Burn out" should not even be in the discussion with most street tires!!!
Anything more than rotating the tires a turn or two to clean junk off of them is more likely to hurt you than help you.
John Force burnouts on street tires is a rookie move.
I would absolutely recommend driving around the water box, if possible, with street tires. There is NO need for water to spin them 1 or 2 rotations, and tracking water up to the start line will result in extremely poor launches.
I run ET Street Radials and LOVE them!!!
They stick very well and can easily be driven to and from the track if you want to.
TRUEBLUE3934 is offline   Reply With Quote
Old 04-22-2012, 07:49 PM   #23
02 SILVER BULLITT
just like trueblue said, i drove around the waterbox and dumped the clutch for a couple of turns to get debris off.
02 SILVER BULLITT is offline   Reply With Quote
Old 04-22-2012, 09:58 PM   #24
Bman2000
you two can say what you like, i understand that street tires are not designed the same, so they don't receive the same benefit from burnouts. But i have proven all i need to for myself to believe that no burnout at all doesn't work. This could be all related to which street tire your choose to run. I would say this and have said this, if you dont think it works fine, but try it before you assume it doesn't. I took my 245 falken street tires, did not burnout fried them off the line and through second(think it was a 2.2 or 2.3 easy on the clutch slipped it out just nothing there to hold it). Did a 5 second burnout roll out of the box till they caught, dry hopped. bam repeatable 2.01 60' times on stock gears and suspension. so call what i chose to do a rookie mistake. But i dont see a lot of rookies driving a mild bolt on mustang in the low 13s. ( no sticky tires, no suspension, no gears, no long tubes, factory wheels, full weight)
Bman2000 is offline   Reply With Quote
Old 04-23-2012, 08:29 PM   #25
TRUEBLUE3934
Summer performance street tires can be quite slippery in cooler weather. Therefore, if it is cool outside and you have those type of street tires a little burn out could add enough temp to keep them from being slippery.
In general, burn outs will not make a street tire sticky. They can in fact create a more slippery condition.
I agree that guys should experiment with different techniques to see what works for them, but don't expect street tires to behave the same as drag tires.
I have seen my buddy 60' 1.7's on plain street tires, but he is remarkably smooth and was getting all he could out of the tires and 500rwhp(turbo). I ran upper 1.9's on my street tires, but never any better than that. It is possible that simply getting it right on the launch resulted in lower 60' and not spinning the tires profusely in the waterbox.
PRACTICE, PRACTICE, PRACTICE is the way to get good launches.
Old 04-23-2012, 10:01 PM   #26
Bman2000
thats true not saying i couldn't have gotten better times without burnouts if i didnt practice, but i do know for those tires anyway i couldn't be aggressive without a burnout, cuz it was like ice. yea i dont know if i could have gotten better than 2.01 i think i coulda gotten 1.9x but sadly as i was getting it down i fried the posi and couldn't get a consistent launch after that.
Old 04-24-2012, 03:16 PM   #27
UPRSharad
Sponsor
UPRSharad's Avatar
Quote:
Originally Posted by 02 SILVER BULLITT View Post
ok, just got back from the track. i might i say that i was VERY disappointed. here are the 4 passes that i made, keep in mind i ran a 13.74 on stock gears, stock 245s, and 35 lbs of air.
pass 1 2 3 4 last year
reaction .190 .117 .044 .195 ds
60 2.59 2.60 2.27 2.30 1.67
et 15.34 14.73 14.59 14.38 13.74
mph 95.37 97.07 96.16 97.11 98.00
launch 2600 2600 2200 2000 2600
on the first pass i made a rookie mistake and didnt unplug the tuner. i went for second gear and got caught on the cord.
both pass 1 and 2 i spun like no other.
pass 3, i lined up against a ws6 ram air trans am and won but let off before the line and he ran a 14.52.
pass 4, i was so sick at this point i was ready to come home and lined up against a honda civic. i beat the ricer by 1.5 secs.
my buddy went with me on both occasions and at the end he only had one word to say "tires". he said that i am putting more power to the ground now and the thin 17" sidewalls cant hold it.
before i put my south side machine control arms on, i think that i need subframe connectors and drag radials. where is the cheapest place to get mt et streets? do you all think this is the way to go before installing the control arms, then shocks?
ok, what do you think? do i go with the 275/60 et street or do i go with a 26x10 or 28x10 hoosier slick?
Quote:
Originally Posted by UPRSharad View Post
If you want to run 12s, especially with the 3.73 gears now, you just traction (and the driver mod)
UPR control arms, Strange 10-way shocks & struts, UPR/Eibach drag springs... and I wouldn't recommend drag radials with a stick car. On 15x8s, I'd run 26x10.5 M/T ET Streets.
http://www.uprproducts.com/mustang-c...ackage-99.html
http://www.uprproducts.com/strange-m...-shock-94.html
http://www.uprproducts.com/strange-m...-strut-94.html
http://www.uprproducts.com/mustang-e...pring-kit.html
^^These parts will drop almost a full second off of some of your sixty foot times. That's nearly a two second reduction in your quarter mile elapsed time. I apologize for sounding like a broken record, but dude, you've GOT to hook if you want to run the number. And southsides & DRs aren't gonna cut it.
UPRSharad is offline   Reply With Quote
Old 04-24-2012, 04:27 PM   #28
Soldier GT
Soldier GT's Avatar
Damn BD you can drive my man!
Soldier GT is offline   Reply With Quote
Old 04-24-2012, 05:07 PM   #29
TRUEBLUE3934
TIRES.
That is the best answer to your issues right now (plus practice).
Beware of salesmen because their stuff is always the best
Get a pair of nice DRs and see if that doesn't fix most of your issues. I bet you will be VERY happy.
Old 04-24-2012, 07:41 PM   #30
uberstang1
Chupacabra
uberstang1's Avatar
Id go with a 26x11.50 Et street, which is a bias ply street legal slick. The et streets in the metric size are radials.
uberstang1 is offline   Reply With Quote
Steeda 555-8241 (Linear) Competition Springs. Gene K S197 Handling Section 1 10-21-2015 11:37 PM
2013 Mustang GT vs 2014 SS Sedan heslekrants Street/Strip 11 09-23-2015 04:02 PM
what are the best phone apps for 0-60 MonsterBilly Classic Mustangs (Tech) 4 09-20-2015 06:56 AM
96 V6 Gauges (Temp) 96stang3.8 V6 (1994-2004) Mustangs 1 09-10-2015 06:42 AM
P0175 zachary1988 4.6L General Discussion 5 09-04-2015 03:04 PM
14, 2000, 410, 94, arms, control, mile, mustang, nitrous, nos, powered, rear, running, street, tires, trim, vbulletin
