Tremec t56 swap into 01 GT? - MustangForums.com
Old 11-20-2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
Old 04-22-2012, 11:07 AM   #1
blown2001slowgt
Default Tremec t56 swap into 01 GT?
just blew my second tr 3650, figured id go with the cobra 6 speed transmission. whats needed to this swap? obviously tranmission.. do i need the harness and k member? will the bell housing bolt right up. also i found a good deal on one out of a c5 z06..would it fit or would i need to change the bell housing?
blown2001slowgt is offline   Reply With Quote
Old 04-22-2012, 11:38 AM   #2
PaladinMan187
Quote:
The input shaft should be different too. If I remember correctly that is the other main difference between the Viper/Cobra/Vette units aside from the bellhousing.
PaladinMan187 is offline   Reply With Quote
Old 04-22-2012, 02:25 PM   #3
blown2001slowgt
Would I be able to use to bell housing off my tr 3650 and input shaft or do I need one from a cobra?
Old 04-22-2012, 03:48 PM   #4
cuban tech
cuban tech's Avatar
the TR3650 does not have a removable bell housing
cuban tech is offline   Reply With Quote
Old 04-22-2012, 04:15 PM   #5
Bpohlman13
Bpohlman13's Avatar
You need a bellhousing, possibly a clutch depending on what tranny you get (26 or 10 spline) driveshaft yoke, trans crossmember. The 3650 wiring harness will work, but you need to wire the reverse lockout yourself.
Bpohlman13 is offline   Reply With Quote
Old 04-22-2012, 04:38 PM   #6
blown2001slowgt
Do you guys recommend I just put steel 1-2 and 3-4 forks instead cause that's what I keep breaking.... If so any links were to buy them? I can't find them anywhere. Or if you don't recommend that what trans do you recommend that is not too expensive
Old 04-22-2012, 07:42 PM   #7
Bpohlman13
Bpohlman13's Avatar
Whats your price range?
Old 04-22-2012, 09:05 PM   #8
blown2001slowgt
1800-2000 I want to get a clutch is possible within that
Old 04-26-2012, 05:20 PM   #9
blown2001slowgt
Old 04-26-2012, 06:30 PM   #10
oxfordgt
oxfordgt's Avatar
What power do you have?
oxfordgt is offline   Reply With Quote
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 08:28 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 07:16 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 09:01 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 05:54 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 10:13 AM
03, 08, classifieds, cobra, gt, harness, list, ma, magnum, mustang, parts, swap, t56, trans, tremec
