UPR control arms
Go with the Maximum Motorsports http://www.americanmuscle.com/maximu...rms-99-04.html
Especially when you can get UPR's Pro Series LCAs for $80 less
Now here's the thing, we have a street setup that is excellent. The control arms are tubular chrome-moly and the bushings are Energy Suspension polyurethane bushings. 9 times out of 10, I recommend these arms for street driven cars. They are $206 with the mf.com discount: http://www.uprproducts.com/mustang-9...l-arm-kit.html
But you said the car "will see the track about every two weeks." That being the case, I'm inclined to recommend our Pro Street setup. It uses a polyurethane bushing at one end and a spherical bearing on the other end. This helps the suspension articulate more freely (quicker 60-foot times and overall ETs) and it also will handle a bit more abuse than our street arms.
http://www.uprproducts.com/mustang-c...ackage-99.html
http://www.uprproducts.com/mustang-b...gs-8-inch.html
Honestly, either option will work well, but the Pro Street setup will run a little quicker and it'll hold up a little better. (Lifetime Guarantee either way)
I am a fan on team z control arms, top notch. Especially if you really want to get serious with the uppers they sell uppers with relocation bracketry which is optimal for drag racing, baseline suspension also sells a set of relocated uppers thats almost the same. I run alot of upr parts, but sorry sharad Im a team z man for arms
I'm a fan of Baseline, they came out with the uppers long before Team Z copied them. I have also used UPR uppers and lowers on my 8sec fox but made brackets for the lowers to get it to hook correctly. I've used more professional stuff for really going fast. I have never used and never will use Maximum Motorsports parts. Too heavy, bad designs and way overpriced. Basicly MM is for turning not going fast.
I went with team z over baseline just on the simply fact Dave Zimmerman was alot more knowledgable over the phone than when i talked to a guy over at baseline, regardless of which you go with your going to get the same results as they are both the same material construction the only difference would probably be stiffness/strength but that would only matter on the O.D and wall thickness of the arms themselves, and there probably about the same.
Keith and I installed a set of lowers on my car.They have a poly bushing at one end and a heim joint at the other end.For the first couple weeks they were doing a lot of creaking.Like they were breaking in or settling.Now they are as quiet as my stock set was.I would recommend them.
