Brake Upgrade
They'll fit on the stock bullitts 100%
You say you had a tough time finding the cobra brakes for under $400 for the calipers and brackets though? I bought brand new bullitt calipers/brackets/pads for $205 shipped from buyfordracing.com lol
A file or sand paper will remove the paint from the letters COBRA just fine. It'll look nice. I've done that before
Still more expensive than what I got mine for Well, excluding the pads.
I'm curious though. I looked on buyfordracing.com and didn't see them. Can you link me the listing? Also, I wouldn't mind shopping for the rears.
I just searched the site and it seems that they took the front calipers off. Hmmm.
You know that bullitts and mach 1's have the same brakes as the cobras right?
I looked daily for 4 weeks before I settled on the ones I bought from the GI Joe in Germany.
I'm not disappointed in the price I paid. I was just surprised when you said buyfordracing.com cause I was certain I checked there.
Also, the Hawk HPS pads are a little pricey. I could have dropped my overall investment if I went wither other pads.
Bought the Calipers over the internet (private seller); Pads from Discountbrakes.com; rotors/piston rebuild kits from rockauto.com and the brake lines from latemodelrestoration.com. Sure beats the stupid $1300 price tag the conversion kits sell for.
Edit: O, I think your buy for $375 is a hellova deal. All four corners? Rear cobra calipers & brackets on average are $275 right now. When did you do yours?
I did my rears when I had my gears installed bc the axles need to be pulled in order to get the moan braces on there. Killed 2 birds with one stone.
I ended up picking up the full rear kit for $75 used locally. Although the rotors are 11.65" as opposed to the GT's 10.5, you can use the GT caliper on the rears as long as you have the Mach/gt/cobra rear bracket (which looks cooler anyway)
As for the fronts. I meant that they are all the same visually. The cobras have raised letters (and some indented), the bullitts have a pony, and the machs have nothing. I think only the 04 cobras have larger pistons 40mm as opposed to all the others which have 38mm pistons. You wouldn't be able to feel that little of a difference anyway.
Quick question.
I was under the impression that all 94-04 Cobra front calipers were the same, with minor exceptions like stamping.
The calipers I got were off a '97 Cobra. I need a Brake Hardware Kit, but this says 99-04.
Will it still fit? I have a feeling O'Reillys database isn't exactly 100% accurate
Brake upgrade done!
Here are some pictures.
I also decided to take the back brakes apart. I wire wheeled the rotors brackets and calipers. Painted the rotors and brackets black. Assembled the brakes and painted the calipers red to match the fronts.
Rear Brakes Before:
Rear Brakes After:
Rear Brakes Before:
Rear Brakes After:
