Another coolant leak!!
Bled the schrader valve, nothing came out. TB/Plenum is off the manifold but the alternator is still on. The water pump pulley is blocking the final bolt from backing all the way out, however even if I set the alternator back in place and put the serpentine belt on, the water pump pulley still spins if I try to remove any one of the four nuts. Any ideas? I might still be able to do the job if the final alternator bolt is still in because I do have wiggle room with the other bolts/bracket off.
...well, ****. The bottom bolt in question is like a perch for the alternator, so it slipped right out.
I pulled the tb/plenum off and fuel rails but some gas dripped out and I'm hoping I cleaned it up enough. Some injectors did not come off with the fuel rails...but they didn't look too bad when I removed them. Also pulled out a spark plug and...it's been in for too long lol (gap is ****ed and has white deposits on the end).
Tomorrow I'm going to do all 8 plugs, torque them right and then pull off the manifold and clean the surface. Does that paper towel/vacuum idea in the link above seem like a good method?
when you remove all 8 plugs, make sure to disable the fuel and crank the motor over with the key for a few seconds. make sure no coolant is in any of the cylinders/intake ports. then install everything. Also, when putting the fuel injectors back in, lube the o-rings with some motor oil before jamming the rail back on
Also, won't the OBDII want to an hero since everything (plugs, injectors, IAC, MAF, alternator etc) is unplugged? Because I figure to get the starter working I would hook up the battery again and install the alternator so the serp belt will crack the engine from the starter.
I don't think there is any coolant in any of the ports since the leak was from the thermostat area..I think.
it will still crank with everything unplugged. no need to put the belt or alt on yet. just hook the battery up, pull the fuel pump fuse, and crank it for a solid 10 seconds with the plugs out and intake off. Do this just before you install the intake back on. After cleaning and wiping down the ports and whatnot. Its always a safe thing to do just in case any coolant managed to drip down there. takes no extra work other than yanking a fuse
