Forged 28 spline axles?
Old 05-04-2012, 08:19 PM
CobraFrenzy
CobraFrenzy's Avatar
Originally Posted by cliffyk
It's called engineering...
Oh ok thx for clearing that up..
CobraFrenzy is offline
Old 05-04-2012, 08:28 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You are welcome, you seemed to be confused.
cliffyk is offline
Old 05-04-2012, 08:42 PM
uberstang1
Chupacabra
uberstang1's Avatar
Cj cobra solid axles have the same axles and diff as gt solid axles you nubber.
uberstang1 is offline
Old 05-05-2012, 11:25 AM
CobraFrenzy
not really, it was a good lecture
Old 05-05-2012, 12:28 PM
HamMach1
HamMach1's Avatar
The stock 28-spline axles are "forged", that's the way anything expected to do that sort of job would be made. Also I would disagree that they suck as they can actually handle quite a bit more torque than the stock engine puts out.
Here are the torque ratings for the Ford 28 and 31-spline axles (from tests performed for Fourwheeler magazine):
COT: Continuous output torque rating
MOT: Maximum output torque rating
Ford 8.8 28-spline COT: 1250 lb-ft MOT: 4600 lb-ft
Ford 8.8 31-spline COT: 1360 lb-ft MOT: 5100 lb-ft
You can see that the 31-spline axle has just an 8.8% higher continuous rating, and a 10.8% higher maximum rating--so it really isn't THAT much stronger.
The aftermarket axle makers claim the splines on their 28-spline axles are stronger then on the stock axles, one maker claims 35% stronger.
That said it is foolish to ever believe anything anyone trying to sell you something says.
Getting back to the stock 28-spline axles, if we assume 4.10:1 gears then 4600 lb-ft out would be 4600/4.10 = 1122 lb-ft in to the rear end. Now if we assume 2nd gear (2.0:1) with perfect traction that's 1122/2.0 = 561 lb-ft into the tranny. If we further stipulate that the engine's peak torque happens around 5252 rpm then that would be 561 fwHP, or 476 rwHP with a 15% powertrain loss.
Now that would be pushing the axles right up to their limit, so if we include a 0.8 design buffer that becomes 476 * 0.8 = 382 rwHP--or just about what most people here would consider to be the limit for the stock 28-spline axles.
Dang nice write up. So in essence, 28 spline are ok for launching with DR's/slicks with 4.10's and not much power/torque?
HamMach1 is offline
Old 05-05-2012, 12:40 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I can't help it, in addition to being a practicing engineer for a good part of my life I was an adjunct professor (lecturer like our beloved leader) at a couple schools...
cliffyk is offline
Old 05-05-2012, 12:42 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Yup, as you can see from the lab tests the 31's are not that much stronger. As long as you are not on "pinks" run 'em until they break and then upgrade...
cliffyk is offline
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
Quick Reply: Forged 28 spline axles?
