1996 Cobra Throttle Body Cleaner decal
I have removed the factory plastic air intake system and there is a decal saying NOT to clean inside. The car has 62,500 miles and is completely original. The two butterfly valves DO have carbon build-up on their insides. Is their a cleaner to use or leave it alone. Any answers will be greatly appreciated.
There is no need to clean the bores unless they are VERY dirty, if you do use the "coating safe" cleaner and do not scrub off the coating.
Ford says do not clean them, and I have never found any benefit in doing so....
Too much air bleed past the butterfly which will mess up the idle speed (this can be corrected by readjusting the throttle stop screw), less resistance to sludge build-up and increased "stiction" causing the throttle plates to tend to stick closed if the throttle is suddenly closed on hard deceleration.
Other than that not much...
But the co. CRC make good cleaning products for intake systems (MAF Cleaner ,TB cleaner..so on) Im sure it would be okay to use their products to clean the throttle plates if need be.
But its just my opinion and .02
GL
FWIW I have never cleaned a throttle body on an FI setup in my life, including those on cars with well over 200k miles, it just isn't something that's necessary. Regardless of how "carboned up" they look, the light layer of carbon actually improves air flow by generating a turbulent boundary layer.
Carburetors are a different animal, I have cleaned more of those than I care to remember. At one time I had a big hot tank boiling them...
JDWalton
09-24-2015 08:47 PM
