97 cobra HP
Old 05-13-2012, 03:50 PM
Yordan Medina
Yordan Medina's Avatar
Default 97 cobra HP
hey there guys i have a 97 cobra and i have twin 62 mm TB, i had no exhaust done besides the buffles cut out and welding a pipe in place , short shifter and a BAMA Performance SCT tune in it but when i dyno the car it only put down 232 hp and 242 TQ and id doesnt feel like it pulls like is supposed to this is my first cobra and it has 53k miles on her could anyone tell if something could be wrong or if those numbers sound about right ..and i just installed some bbk x pipes and flowmaster 40 series and retuned it with the same BAMA SCT tunner and havent taken it to the dyno yet ..thanks fellas for all the help.
Yordan Medina is offline
Old 05-13-2012, 03:59 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
I'd bet your IMRC's aren't opening, they seem to have a fairly high rate of failure as the car ages.
1998Slow 'Stang is offline
Old 05-13-2012, 04:29 PM
Yordan Medina
what exactly is that and how would i fix that problem..and what does it stand for i was told once but i cant seem to remember.
Old 05-13-2012, 04:33 PM
JC316
JC316's Avatar
+1 to the IMRC's.
They block off some of the intake ports to increase port velocity at lower engine speeds, helps with low speed torque. They are just little butterflies that slap shut below 3250RPM and open above. Usually they get gummed up. One way of fixing them is seafoam, another is to take the intake off and clean them.
JC316 is offline
Old 05-13-2012, 04:39 PM
Yordan Medina
i tried that seafoam but i only used the one for the gas idk how toput it on the rest of the car do you know by any chance and could you explain it to me if so.
Old 05-13-2012, 04:44 PM
JC316
JC316's Avatar
Should be directions on the can. Basically start the car, disconnect a vacuum hose that goes to the intake, then suck the seafoam in, try not to let it die until you get the recommended amount in. Once it's in, you kill the car and let it sit for about 20 minutes. Then you start it up and prepare for the smoke show.
JC316 is offline
Old 05-13-2012, 04:46 PM
Yordan Medina
yeah thats the thing i couldnt find the bacum line.
1998Slow 'Stang
I personally don't care for seafoam, but you can put it in slowly through the PCV line.
The right way to fix this problem would be to take the intake off and clean them away from the engine, or get rid of them all together.
IMRC = Intake Manifold Runner Controls, I believe.....
They look like this (Maybe aluminum for you:
Old 05-14-2012, 01:22 PM
uberstang1
Chupacabra
uberstang1's Avatar
Delete them, end of story.
uberstang1 is offline
Old 05-14-2012, 02:01 PM
Yordan Medina
so what do i need to do after i delete them ? do i have to tune the car ad is the check engine going to come on any sensors or plugs of any type ? thanks .
Quick Reply: 97 cobra HP
