4.6 to a 5.4l
Old 05-25-2012, 09:25 AM
StangKid018
StangKid018's Avatar
Default 4.6 to a 5.4l
Alright so.. now that I've S/C the 4.6 I'm interested in now taking a new step at something more intense while over the summer going into winter and maybe plan a next spring 5.4L swap. Need more...
So, my question is everyone. What are my best options taking on this build and what will I need for the people who have done it or have looked into doing it themselves.
StangKid018 is offline
Old 05-25-2012, 09:38 AM
PNYXPRESS
PNYXPRESS's Avatar
Easiest way would get an entire donor car. plus double check to see if the 2000 cobra R used the stock k-member or a specially designed one. You will more than likely need a new hood also.
PNYXPRESS is offline
Old 05-25-2012, 10:43 AM
school boy
school boy's Avatar
op, you will mostly gain a little torque and not a lot of hp with a stock 5.4, the rods are still weak. i would go ahead and aleast put forged pistons and rods so you can crank up the boost. other than a 5.4 short block, you can use your heads and everything will bolt right up except long tube headers (shorties or stock required or special 5.4 long tubes) and 5.4 intake manifold adapters.
school boy is offline
Old 05-25-2012, 12:53 PM
PNYXPRESS
PNYXPRESS's Avatar
if he uses a stock gt500 5.4 then he will see more than a little torque and hp increase.
Get in touch with boozshey on here. he has done a couple of these swaps in s197 cars
Old 05-25-2012, 01:08 PM
Rockwell28
Rockwell28's Avatar
OP why not just look into blower cams and forged internals down the road for your 4.6?
Rockwell28 is offline
Old 05-26-2012, 12:33 AM
AJB540
AJB540's Avatar
Forget the engine and build up the suspension.
AJB540 is offline
mdj89
10-26-2015 11:53 AM
10-09-2015 03:27 PM
rksnow1
09-14-2015 08:46 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: 4.6 to a 5.4l
