coolant light keeps coming on
Had to replace the stock intake manifold a few weeks ago and I replaced it with the ford racing performance improved manifold. Replaced the thermostat and temperature sensor. New plugs and coils and boots. Cleaned the injectors and put new seals on them... everything runs fine no leaking car never gets over halfway on the temperature gauge. But for some reason the coolant light keeps coning on. Off when i first start it but 5 10 15 mins in it's always coming back on... what could cause this? Would a code reader tell me anything?
Yep right at the full line. Checked 4 or 5 tines after i swamped everything. Hasn't lost a drop. I believe you right it may be the thing in the tank... umm the float I remember having trouble with that now. Sometimes I had to tap the tank to make it raise to the top. Ill check it out.. thanks man ill let you know something
mine did this, after putting in cams i kept getting the coolant light on when the level was good, I ended up just unplugging the sensor cause i got so tired of it, with it unplugged it never comes on now and I always watch my guages good so i'll notice if the car were to ever get hot for some reason.
^ what he said. the temp sensor is on the intake. this is just a float in the coolant jug bottle. i'm assuming over time the float gets stuck/damaged causing the lights to come on and off at random sometimes.
Diode Dynamics
28
05-26-2022 12:02 PM
soulcaliber39
12-28-2016 04:57 AM
Calizic
08-28-2015 01:46 PM
