Scing this week, got some ?
Old 07-22-2012, 03:00 AM
Bman2000
Bman2000's Avatar
Default Scing this week, got some ?
So starting Tuesday car goes down for install, finally after 3 years, haha. Anyway So i have the s trim and all the brackets and a diy inter-cooler. My side goodies are 42# injectors ford gt pump(no pprv valve) hpx slot style maf (05 and newer maf) 50mm tial q bov.
So heres me question. Its mostly about where to put stuff inter-cooler wise. From what i understand, maf need to be in the longest part of the pipe, basically best spot is right before the tb, minimum of 6 inches after the pipe straightens out from the fender right? Then the bov, basically a few inches after the discharge on the sc, before the inter-cooler right? and lastly what do i do about the IAT? do i create a bung for it and use the stock one? or is this new style maf need a different iat set up? cuz im totally lost on that. Maybe if anyone has a picture of thier set up with similar stuff in it? its just i have to weld all that stuff in, and id rather not screw it up and find out it need to be different when i get to the dyno, a lot of work and money to replace that stuff. any help would be great.
Thanks. Also if there are any other things i need to watch out for with this set up please let me know.
Bman2000 is offline
Old 07-22-2012, 08:25 AM
MCxQubed
MCxQubed's Avatar
Here's a few pictures of mine, you can see where the maf and bov go on my setup.
the bov is mounted between the blower and the intercooler, on the pipe going to the intercooler
MCxQubed is offline
Old 07-22-2012, 10:17 AM
scooter3
scooter3's Avatar
Here are a couple pics of mine. Your HPX has the IAT sensor already so you should not need to worry about that. Just make sure you have at least 4 inches of straight pipe on each side of it. Your BOV will be on the down pipe coming off your S/C right before your intercooler. If you need any more pics let me know. You are on the right track.
scooter3 is offline
Old 07-22-2012, 09:24 PM
Bman2000
Bman2000's Avatar
Thanks, thats kinda what i thought. 3 years of putting this crap together and studying, you tend to forget stuff. In anycase, 3.6 is the standard 8 psi pullie right? if so i should be able to get away with a 3.33 without changing belts and without having issues with belt slip correct? Also anyone know if anyone has just made their own power pipe? Cuz i was thinking just use a what is it 2.5 to 4inch coupling off the sc intake and just run a 90 4 inch pipe over to my dense charger intake and just hook it up to that since its already an in fender cia that 4 inch. anyone got any thoughts on that?
Bman2000 is offline
Old 07-23-2012, 01:30 AM
scooter3
scooter3's Avatar
I am running a 3.33 pulley and am at about 10 pounds of boost with my powerpipe. I have not changed my belt and I have no slip. If you can make your own powerpipe it will save you some cash. Not hard to do. Do a search on the powerpipe, there are a couple threads from guys who have made their own.
scooter3 is offline
Old 07-25-2012, 07:57 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
I got a 6 rib 3.33" pulley for sale pm me if interested.
Mustang_NTriangle is offline
Old 07-25-2012, 08:03 PM
Bman2000
Bman2000's Avatar
thank you for the help....Just figured out some crappy news, first i burned through my brand new wide band wires....awesome get to fix brand new stuff. second apparently i thought i had been running 2.5 inch exhaust for the past 5 years, turns out its pretty much factory minus mufflers after the x pipe. glad i caught that before i tried to make 400rwhp on the dyno haha
Bman2000 is offline
Old 07-25-2012, 08:04 PM
Bman2000
Bman2000's Avatar
also where could i find an aluminum bung for the iac connection?
Bman2000 is offline
Old 07-25-2012, 10:58 PM
Bman2000
Bman2000's Avatar
and the installation of the sc bracket and what not, where do i find that? is that just downloading the vortech install manual or is there a better easier way to get the directions.
Bman2000 is offline
Old 07-26-2012, 10:41 AM
MustangMan00
MustangMan00's Avatar
bung for IAT...
http://www.diyautotune.com/catalog/3...sor-p-107.html
IAT sensor at advance p/n....WT3085
and yeah just download the manual
MustangMan00 is offline
Quick Reply: Scing this week, got some ?
