Overheating problem
Old 07-22-2012, 02:26 PM
03mustanggtlm
03mustanggtlm's Avatar
Exclamation Overheating problem
i have a 03 mustang gt and it has been overheating and coming out the top of the coolent tank . i have replaced the thermostat , waterpump and had a coolent flush . it ran fine for a week after that but the other day overheaded again . and it only does it when im driving in the city . i put more coolent in it and checked it a day after and it was all gone but i dont see no leaks . when i turn off my car there is always a pressure sound coming from the coolent lid . so . but the lid looks fine . and my fans are working . do you think it might be the radiator ? any thoughts
03mustanggtlm is offline
Old 07-22-2012, 03:16 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Get the radiator flow tested, it is likely clogged and cannot shed heat fast enough at lower vehicle speeds.
Your 2003 has "fans"
cliffyk is offline
Old 07-22-2012, 04:44 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
replace the coolant bottle cap. if it wont hold pressure it will cause you to overheat
WhiteFoxGT is offline
Old 07-22-2012, 05:11 PM
JC316
JC316's Avatar
That. Plus, you are in Texas and it's hotter than hell right now. My 96 was getting plenty warm yesterday
JC316 is offline
Old 07-23-2012, 12:54 AM
Bladerunner
Bladerunner's Avatar
Your radiator is probably the culprit if you replaced all those
parts and it still overheats.
Your radiator is more than likely clogged/corroded and needs
to be replaced.
Bladerunner is offline
Old 07-23-2012, 09:00 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
to be replaced.
do the world a favor.....go find the nearest tree, and climb it with your neck
mungodrums
09-29-2015 09:18 PM
stangin1996gt
09-21-2015 11:01 AM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Overheating problem
