Another tire thread lols.
Old 08-19-2012, 07:53 PM
SVTeeshirt
SVTeeshirt's Avatar
Default Another tire thread lols.
Okay i prob should get a picture for you guys, but maybe i don't need one, i have 17x10.5? cobra wheels on my car... (not wheels in sig) and i have 315s out back and need new rear tires, is there any reason I couldn't go to a 305 rear tire?
Oh and i wanted to go to a 305 to avoid rubbing on my brake line brackets around turns, i don't wish to use a spacer at this point.
SVTeeshirt is offline
Old 08-19-2012, 08:06 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
go for it
WhiteFoxGT is offline
Old 08-19-2012, 08:09 PM
ctgreddy
ctgreddy's Avatar
305 would be fine but i dunno who makes that. usually it's either a 275 or a 315 for a 17" wheel. i've never heard of anything rubbing on that, any way to modify it to clear?
ctgreddy is offline
Old 08-19-2012, 09:17 PM
school boy
school boy's Avatar
couldnt find 305s, heres 295 35 17s:
http://www.ebay.com/itm/TWO-NEW-KUMH...sories&vxp=mtr
school boy is offline
Old 08-20-2012, 06:06 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Why would 305's rub, if you already run 315's? My guess is they are a 40 series?
Jazzer The Cat is offline
Old 08-20-2012, 08:40 AM
SVTeeshirt
SVTeeshirt's Avatar
I didn't do my research I can't even find 305s in 17s.. Idk if I want to go to a 295. And I'm saying my 315s rub slightly so I wanted slightly smaller... Guess I should get small spacers. I looked on AM and Nittos are $225 each for 315s.. cheaper anywhere else?
Old 08-20-2012, 08:41 AM
SVTeeshirt
SVTeeshirt's Avatar
Also pretty sure they are 35s.
Old 08-20-2012, 01:10 PM
teej281
4.6L Section Moderator
teej281's Avatar
Run a panhard bar so there wont be any side-to-side movement in cornering. And which nitto's are you talking about? Drag radials?
teej281 is offline
Old 08-20-2012, 08:43 PM
Jay-rod427
Jay-rod427's Avatar
315's already look goofy on a 10.5" wheel because the wheel is almost as wide as the tire, going any smaller is going to make the wheel wider than the tire and that's no good. stay 315's and put on a 1/4" spacer. IMO.
Jay-rod427 is offline
Old 08-20-2012, 11:21 PM
Jazzer The Cat
Retired Moderator
^ depends on what you are after
A narrower tire will hold a better lateral line and extremely difficult to not get push with 315's out back.
Jazzer
Quick Reply: Another tire thread lols.
