New From MASS
Old 08-23-2012, 09:22 PM
Saucy
Saucy's Avatar
Default New From MASS
Hey guys just purchased an 04 Gt for $7k. Looking for more horses as we all are. Any suggestions besides the normal KB, tune, intake, exhaust? Thanks
Saucy is offline
Old 08-24-2012, 01:10 AM
Convex
Convex's Avatar
Well i have a pretty stock 2001 GT vert (auto) other then added flowmasters to stock exhaust and have had time to drive it as such (as i bought it July 3).. it had good power but getting it to (get a wheel) was alittle tough with traction control on.
My first mod was a SC3 x3 hand held tuner from BAMA to which i have tired Street and Performance tunes but not Race yet.. current is Performance tune and the car has alot of added torque as i can override traction control now without turning it off from a dead stand still without useing the brake as it will light them up and make the car go side ways and bark the tires when changing 2nd gear.. it's not a 426 Hemi but for the money it's one of the best upgrades and gets the car where it's should of been from factory.
Convex is offline
Old 08-24-2012, 03:46 AM
mustangman02232
mustangman02232's Avatar
Where about in mass?
mustangman02232 is offline
Old 08-24-2012, 07:25 AM
uberstang1
Chupacabra
uberstang1's Avatar
Welcome to the forum.
uberstang1 is offline
Old 08-24-2012, 07:28 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You have pretty much described the meaningful bolt-ons, I generally recommend the following, in this order:
  • Open up the exhaust, 2-1/2" from the manifolds to the back bumper. Install an H- or X-pipe per your pleasure, the only practical difference on the street is the sound. H-pipe = Musclecar, X-pipe = NASCAR. Select "off-road" or catted, again it makes no practical difference--o/r pipes are louder.
    There are many that say chambered mufflers like the Flowmasters sound better with H-pipes, and that straight through mufflers like Magnaflows sound better with X-pipes. Having owned both combinations (and scrapping the H-pipe and Flows) I am among them.
  • The next thing to do is to buy a tuner, handheld with "tunes for life" or a more sophisticated system if you plan on doing your own tuning. The stock tune was designed to make the EPA happy, run on 87 octane swill, and insure that there was no way a GT owner could possibly hurt the engine, regardless of how hard they romped on it. The ignition timing is absurdly conservative, and in open loop it runs pig-rich; especially the '03s and '04s with the pink 21 lb/h injectors, that will dip into the low 11s and even high 10s AFRs at WOT.
  • Then if you want to wake up street performance change the rear-end gears. The ratios 3.73:1 and 4.10:1 are the most popular--I will not get into which is "best" as that is a very subjective discussion. I will say that I got 3.73s when my engine was near stock, and if I had it to do over again I would have installed 3.55s or even stayed with the 3.27:1 stock gears.
  • After the above install an aftermarket upper plenum and 70 mm throttle body. Again it really doesn't matter which maker--read more about that here. Some will say get a 75 mm TB if you plan on going f/i some day, to which I say nonsense. In the first f/i and n/a are distinctly different environments with regard to intake flow, and in the second a supercharger or turbocharger will cost so much that another $100 will be a ****-hole in the snow by comparison--and you can easily sell that 70mm TB on eBay for $50 to $60.
Beyond the above there really isn't much to do in the "bolt-on" realm. CAIs (Cold Air Intakes) are a complete waste, some actually hurt engine output. The stock intake is a CAI and a very good one at that.
Things like underdrive pulleys, lightweight flywheels and aluminum drive shafts can improve acceleration, but only if you are a "drive it like you just stole it" (DILYJSI) )sort of person. I have those things, and must admit that upon occasion, under safe conditions, I am a DILYJSI sort of driver.
Don't waste money on after market COPS, fancy spark plugs, cotton gauze air filters, special oil treatments or anything where the person selling it presents claims that don't make sense. The reason they don't make sense is because they don't make sense.
If there were some magic elixir or device that could actually improve fuel economy or power the automakers would be buying or licensing it to make the Corporate Average Fuel Economy higher, or to give them bragging right over the competition. They don't because there is no magic or snake oil.
Above all keep in mind that of Cheap, Fast and Safe you only get to pick two.
BTW, I lived in Plymouth for 45 years--been down here for 20. I miss crisp clean air; there is a permanent musty smell here that you do get used to, and having four seasons; we have 2-1/2, hot friggin' hot, and nice--but I do not miss scraping and shoveling--not one bit...
cliffyk is offline
Old 08-24-2012, 07:37 AM
03gt04mach1
03gt04mach1's Avatar
Welcome Saucy. There's always room in the Corral for another Mustang. Seems to me like you got a DEAL. Hope it's in real good shape. Welcome again.
03gt04mach1 is offline
Old 08-24-2012, 07:21 PM
Saucy
Saucy's Avatar
North Shore
Saucy is offline
Old 08-24-2012, 07:30 PM
Soldier GT
Soldier GT's Avatar
welcome...
Soldier GT is offline
djbigskrilla
09-20-2022 01:04 AM
67LimeCoupe
11-25-2015 08:55 PM
uedlose
09-10-2015 03:30 PM
dfw692
08-07-2015 11:53 PM
Quick Reply: New From MASS
