Vortech supercharger leaking
Old 10-22-2012, 09:59 PM
TCStangerv6
TCStangerv6's Avatar
I don't think its the blower that's not aligned right. I got the dimensions for the spacers and made them at work down the .0001. It looks to be the ac pulley because its jumping a rib off and breaking the side of the plastic pulley you get from the ac delete....
TCStangerv6 is offline
Old 10-22-2012, 10:05 PM
Jay-rod427
Jay-rod427's Avatar
For what kind of power you are looking to make you really should have the blower belt "renegade" style on its own. I know the last thing you want to hear is re-doing something...
Jay-rod427 is offline
Old 10-22-2012, 10:23 PM
TCStangerv6
find a kit for me and i'll put one on.
Old 10-22-2012, 10:26 PM
uberstang1
Chupacabra
uberstang1's Avatar
www.houseofboost.com
uberstang1 is offline
Old 10-22-2012, 10:28 PM
uberstang1
Chupacabra
uberstang1's Avatar
Nevermind had a brain fart, your on a vortech HOB only has procharger belt systems.
Old 10-22-2012, 10:30 PM
TCStangerv6
got me all happy and wet for nothing... btw I seen the lip you were talking about but someone on moddedmustangs. said you can tap it in to far. I think I did because it seems like its having a hard time turning by hand.
Old 10-22-2012, 10:37 PM
uberstang1
Chupacabra
uberstang1's Avatar
It shouldnt effect how hard it is to turn the blower, the seal shouldn't be able to make it past that step and interfer with any moving peices inside the headunit, unless that ysi has some strange design), and the shaft shouldn't be tapered either it should be the same diameter straight into the head unit. Are you still on 6 rib pulleys?
Old 10-22-2012, 10:41 PM
TCStangerv6
No I ditched the 6 rib a long time ago for a 8 rib. Well the bearings are right there but I don't think it's touching them.
Old 10-22-2012, 10:42 PM
uberstang1
Chupacabra
uberstang1's Avatar
What 8 rib pulley did u use on the ac delete bracket that you got to work? What was it from? Expecially if its plastic
Old 10-22-2012, 10:45 PM
TCStangerv6
It's an ac delete for a 5.4 triton motor. Why is it made out of plastic I don't know... Honestly I hate that it's plastic and I wish I could find a metal one. I'd make one at work if I wasn't laid off...
Quick Reply: Vortech supercharger leaking
