t-56 vs C4 at track auto guys help me!!!
Old 11-07-2012, 05:49 PM
1fast 99gt
1fast 99gt's Avatar
Default t-56 vs C4 at track auto guys help me!!!
so i am selling my t-56 magnum to go with a fully built and rollerized c4 trans with reverse manual valve body. i wanted to see how much faster at the track/ street i will be. seeing if anyone has done this with results.
1fast 99gt is offline
Old 11-07-2012, 06:54 PM
uberstang1
Chupacabra
uberstang1's Avatar
Well what are ur current times and traps can't know without that.
uberstang1 is offline
Old 11-08-2012, 06:10 AM
ctgreddy
ctgreddy's Avatar
depends how good your driver mod is. if you can drive great, then i dont see an auto getting too much of better times, maybe a tenth or two. consistency and ease will be way up, and imo fun factor will be way down.
ctgreddy is offline
Old 11-08-2012, 11:20 AM
1fast 99gt
1fast 99gt's Avatar
yea right now iam within a tenth of a sec so my consistency is fine
Old 11-08-2012, 12:15 PM
ctgreddy
ctgreddy's Avatar
well then hows your shifting? if you can bang gears then i see no point in switching. if you are having trouble wether it be you or the trans then change it out. the n2mb box may be something to look into as well i put it on my car and it really helped me on the shifting i was a sub par shifter before now after that and just more seat time i'm pretty decent. if you can swing it i'd go 4r tho because losing overdrive would suck ballz if you take your car out for some fun.
ctgreddy is offline
Old 11-08-2012, 01:08 PM
TonyG
TonyG's Avatar
A well-built auto will net you huge gains, typically 0.5s in the 1/4 mile for a 400-500 rwhp car. I see it all the time. The more power you make, the more it'll benefit you. For peaky centrifugal blower setups, the gain can be even more (closer to a full second) because the faster shifts will keep the rpms up high and the engine under boost.
TonyG is offline
Old 11-08-2012, 04:52 PM
ctgreddy
ctgreddy's Avatar
I wouldn't go as far as saying half a second, especially if you have a stick and you can actually shift it, and hook up/launch good. Take the ported eaton cobras for instance, the top 2 fastest are both 9's, one is a 6speed with a best of 9.91 and the other is an auto running a best of 9.81, so .1 difference in a 9 second car, both have very similar build other than the trans.
now if you're not a good shifter and if you cant hook with the stick then i'm sure you will pick up .5 or more with an auto swap.
ctgreddy is offline
Old 11-09-2012, 10:50 AM
TonyG
TonyG's Avatar
Yes, past the 500-600 rwhp level, even experience dragracers will gain a half second to a full second when they switch to autos. But they lose a couple MPH due to the power loss. It's not because they are "bad drivers," it's often because the beefier transmisisons like the T56 are difficult to powershift. I powershifted my T45 all day, but when I switched over to my T56 (b/c T45 was too weak) my shifts slowed down a lot. The T56 is a much stronger transmission but its also more clunky and gives a lot more resistance in the shifts. People who run 9's with a manual tranny probably have them faceplated, which will give butter smooth powershifts at 7000 rpms. But I doubt the OP wants to do that. Even if he does, it is still hard to compete with built automatics, which shifts on millisecond timescales. When you see someone dipping into the 10's at only 120 mph, you know it must be an automatic.
TonyG is offline
Old 11-09-2012, 01:01 PM
1fast 99gt
1fast 99gt's Avatar
So I am at 130 mph what do u think I will be at with the auto at the trap
Old 11-09-2012, 03:06 PM
dwtjr3
dwtjr3's Avatar
OP I sent you a PM
dwtjr3 is offline
Quick Reply: t-56 vs C4 at track auto guys help me!!!
