Weird issue with auto transmission
Old 12-01-2012, 09:31 AM
Blk003GT
Blk003GT's Avatar
Default Weird issue with auto transmission
when i go to shift the tranny into reverse or drive it dosent move i have to give it gas (prolly around 1500 or so rpm) until it will kick into both reverse and drive. i seem to hear fluid moving when i rev it (which i guess could be coolant) and when it does go into gear it kinda slams into gear but once in gear its strong i can floor it and it hooks right up and theres no slipping.
i would say its a torque converter issue but i don't understand why when its in gear its strong.
Blk003GT is offline
Old 12-01-2012, 02:07 PM
Mike T
Mike T's Avatar
Does it go into gear quicker after it's at operating temp or about the same.
Mike T is offline
Old 12-01-2012, 05:29 PM
Blk003GT
Blk003GT's Avatar
it actually seems to go into gear better when its cold when i first start it. and when i come to a stop if its a very quick stop it still stays in first but if i sit for a second then it wont and i'l have to rev it again
Blk003GT is offline
Old 12-01-2012, 05:34 PM
03gt04mach1
03gt04mach1's Avatar
Check the Fluid level, with the car in Park and flat area. Let it warm up first. If the Level is in normal range, may be time for a fluid and filter change. The filters are a cloth type and harden over time, restricting the flow. But, Fluid level check it first.
03gt04mach1 is offline
Old 12-01-2012, 06:10 PM
Blk003GT
Blk003GT's Avatar
fluid level is good i just did a fluid and filter change...i bought the tranny from a junk yard and just put it in... the fluid that came out was pretty nasty and the filter was pretty nasty too. So honestly i really don't have a clue about the condition of the torque converter or anything. i almost hear a noise like you hear when your power steering is low... i don't think its the power steering pump but thats kinda the sound that i hear but the fluid is at the correct level
Blk003GT is offline
Old 12-01-2012, 06:14 PM
Blk003GT
Blk003GT's Avatar
the fluid actually seems pretty black still even after i changed it.
Blk003GT is offline
Old 12-01-2012, 07:41 PM
Blk003GT
Blk003GT's Avatar
and definitly goes right into gear for a minute or so when cold
Blk003GT is offline
Old 12-02-2012, 04:43 AM
Mike T
Mike T's Avatar
Whoever owned the car this transmission went in used it up. Transmission fluid has to be changed at certain intervals just like motor oil. The combustion process turns motor oil black and that's to be expected. But when transmission fluid turns that color it's gone too long with out being changed and it's time for a rebuild or replacement. The junk yard sold you a transmission that was used up and if it were me they would be taking it back and giving me another one.
Mike T is offline
Old 12-02-2012, 07:44 AM
03gt04mach1
I agree. Since you bought this tranny at the junkyard, they should have some kind of return policy. The noise you hear could be the torque converter. The turbine blades sound like they're rubbing against each other, not good, and there is no way they can blame you for that. When you changed the fluid, was there VERY FINE metal shavings in the pan, like clumped up mud? If so, that's the metal inside the converter getting into the internals of the tranny, and sticking the Valve Body.
Old 12-02-2012, 08:49 AM
Blk003GT
Blk003GT's Avatar
ya thats exactly what there was... like mud completely covering the magnet in the pan and the filter was gooey too... it just sounds like something is completely wrong with the tranny... i'm going to call them monday and try and get my money back.
Blk003GT is offline
Quick Reply: Weird issue with auto transmission
