Service engine soon? Po190
Old 07-30-2013, 08:44 AM
timritchieblue
timritchieblue's Avatar
Default Service engine soon? Po190
So I went to get my car tested for emisions,,,
NOT GOOD.. REJECTED
I never have had a engine light on, after my test, driving home, and light comes on?? Scanner says code po190? What to check now? Fuel pump?
timritchieblue is offline
Old 07-30-2013, 10:12 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
P0190 indicates Vref (the nominal +5 V reference voltage supplied by the PCM) is not within the range 4.0 to 6.0 V at the Fuel Rail Pressure (FRP) sensor; more about the possible causes here.
I see you are running a "built" engine, are you still running the returnless fuel system? If you converted to return-style and removed or disconnected the FRP sensor then you need to change the Fuel System Type scalar value in the tune to 0, to disable the PCM's monitoring of the FRP sensor. This should stop it from throwing DTC P0190...
cliffyk is offline
Old 02-06-2014, 02:45 PM
timritchieblue
Going to try a FLPS? I'll try to stay off the rev limiter
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Service engine soon? Po190
