Power needed.... You tell me...
Old 01-31-2013, 03:00 PM
bopiela
bopiela's Avatar
Default Power needed.... You tell me...
Hey guys,
I had been thinking about the next project for my car without thinking all the way through it. With the I/C 3.12 s/c setup I have, my power is maxed out due to the fuel pump (stock plus BAP). I was considering long tubes next - which would be useless without the fuel pump! Sooooo, what would you do in terms of the fuel pump knowing extra mods would be added as well. I need to replace the fuel sensor also, so eventually I need to man up and drop the tank. Looking for options and opinions. Since I'll be changing so much, I want to only tune it once so I'd like to plan my next few mods as a package.
Thanks gents.
bopiela is offline
Old 01-31-2013, 04:30 PM
Gt04
Gt04's Avatar
How much dime are you looking to spend? That will be the biggest help for suggestions
Gt04 is offline
Old 01-31-2013, 04:46 PM
bopiela
bopiela's Avatar
Money is up in the air. Depends on what my options are. As reasonable as possible would be best!
bopiela is offline
Old 01-31-2013, 08:07 PM
Gt04
Gt04's Avatar
you could always take the easy route and throw a svt or gt pump in with the bap or throw a dual pump hat in. I run the glenns performance sleeper system now and i am more than happy with it, but you're looking at a chunk of change for the full system.
Gt04 is offline
Old 01-31-2013, 10:23 PM
Fillerdust
Fillerdust's Avatar
Did u install all the parts? A mustangs tank is light when low on fuel, so I don't see why its an issue to put a bigger pump in.
Fillerdust is offline
Old 02-01-2013, 06:51 AM
school boy
school boy's Avatar
i would look into going with dual pumps. either with a 03-04 cobra hat or aftermarket hat. or you could pick up a complete 03-04 cobra tank with better baffling and drop two gt supercar pumps in
school boy is offline
Old 02-06-2013, 04:25 PM
bopiela
bopiela's Avatar
I don't want to go overboard. I don't think I need a new tank... Dual pumps makes sense... what gives me best range per dollar? I doubt on my block and trans I'll be doing anything other than LT's on top of my current setup so I don't need tons of extra fuel availability
bopiela is offline
Old 02-06-2013, 04:29 PM
chevydillan
chevydillan's Avatar
Just get rid of that boost a pump whatever you do. It's just a band aid in the first place.
chevydillan is offline
Old 02-06-2013, 05:12 PM
dwtjr3
dwtjr3's Avatar
BAP's are great for mild setups.
If you plan on staying around 400 rwhp there is no need to build a fuel system IMO
get a gt supercar pump and a bap just incase to be safe.
dwtjr3 is offline
Old 02-06-2013, 05:33 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
^ this
Ford GT dump (you have to upgrade the FPDM also) and you should be able to support 400wheel easily
WhiteFoxGT is offline
Quick Reply: Power needed.... You tell me...
