How come my 1/4 mile times suck!!!??
#31
I don't think it is a big deal. I went to the track once on street tires with 4.10's and o/r H and a catback and my best pass that night was 14.545@99 with a 2.2 60'
Same car with a set of DRs went 13.6@100.6 with a 1.85 60'
DRs, practice, and faster shifting will get you there unless there's an issue with your TB/plenum and air fuel ratios.
#32
What are your shift points? With cams you should be shifting in the 6100-6200 area. Do you have a dyno graph of your torque curve?
EDIT:
There is a bit of misinformation on when to shift, i actually did the math and even with my old set up (pi swap and a few goodies) my shift points were 6150, 6000, 5800 (6000 for 5th, never get there in a 1/4). Even though your power is dropping off you shouldnt shift until basically the resulting shift will bring you more torque then the ratio of the current gear ratio/next gear ratio. You want the maximum torque being applied to the road of course. I made a matlab program to graph these in my spare time. It shows a basically stock torque curve modified for each gear (T45), each curve goes from ~2000 to 6200rpm.
EDIT:
#33
all i know about shift points was i shifted at 6k each gear, and trapped in 3rd with my simple bolt ons. people used to say you get faster times by shifting early out of 3rd into 4th. But i consistently ran low 13s not doing that. Full weight car best time 13.39 stock tires. no idea why my shift points are now, but i ran a 12.4 shifting at 5800 all 4 gears. of course im limited at this point by my rev limiter because of fuel issues its only 5900
#34
2010 Blue Ball Award Recipient
#35
EDIT:
EDIT:
#37
