getting ready for some track time. what will I do @1/4mi
Old 04-14-2013, 01:30 AM
Bman2000
Bman2000's Avatar
it will all be track prep in my opinion. if you can hook then mid low 13s. hook is the big one, are those true drag radials? or a dot bias ply slick? if they are drs and you can get a 1.9 your doing well, but you wont get that 1.9 at 4k with good track prep, i got my 1.9at 3500 slipping the clutch a bit. if they are bias ply youll need more than 4k. Think of it this way, you always want forward movement, and you can feel what im talking about if you bog you need more aggressive rpm or less aggressive clutch one or the other not both change one at a time. you want the drs to make noise imho(angry squeal). if they go up in smoke thats too aggressive, they also tend to make less noise when being too hard on them. If your running bias plys, i have no clue what those need sorry ha.
if you listen carefully you can hear the angry squeal im talking about that i think you want, but cars kinda loud sorry.
Bman2000 is offline
Old 04-14-2013, 05:22 AM
TRUEBLUE3934
TRUEBLUE3934's Avatar
I think you are pretty close with your estimate of 13.4.
A 13.3 is possible, but I'm more inclined to guess 13.45.
Good luck and have fun!
TRUEBLUE3934 is offline
Old 04-14-2013, 10:11 PM
nascrchi
nascrchi's Avatar
Thanks for the input. I know what you mean by tgat angry sqeal as well.
As for the tires i got the Hoosier R6. According to tirerack.com,
"The tire’s internal structure features a symmetric construction that uses nylon cord radial casing plies reinforced by two lightweight steel belts and a spirally wrapped circumferential nylon cap ply under the tread. The tires feature a rim recess design on all sizes. Additionally, their symmetric tread design and internal construction allows them to be mounted on either side of the car (and later be remounted inside out to further extend their life)." In other words drag radial right. I scored a pair that had two passes on them for 150.
Got a question though, the tr3650 is the same as the tr3650-9 correct? Someone nis selling one to me for 275. I need to asap.
nascrchi is offline
Old 04-15-2013, 02:08 AM
nascrchi
nascrchi's Avatar
Nevermind i found it
www.rsgear.com/articles/2007_08.pdf
nascrchi is offline
Old 04-15-2013, 02:10 AM
nascrchi
nascrchi's Avatar
nascrchi is offline
Old 04-15-2013, 09:45 AM
BraMas
BraMas's Avatar
You do realize the Hoosier R6 is a Roadrace tire right?
BraMas is offline
Old 04-15-2013, 10:58 PM
nascrchi
nascrchi's Avatar
Yea I knew before buying em. Even saw them in action at the track on those 2 passes. Dude broke his axle on his Roush. And at 150 a pair! I couldn't pass that up.
nascrchi is offline
BOB ROME
07-26-2023 01:54 PM
baddog671
07-26-2016 01:20 PM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: getting ready for some track time. what will I do @1/4mi
