Lowering springs/Control arms, cheap vs expensive help...
Ya they make noise with the MM plates, thats about it. But strange 10 ways are gonna be the best bang for your buck for street/strip performance. If its a drag car shell out the big bucks for AFCOs
Hi everyone, I want to lower my 99 GT convertible but need some help and advice because im on a budget. My GT's suspension/struts are all stock except for a Eibach Anti-Roll sway bar kit I put on it last year. I am on a budget because I just spent 650 on a shaker hood system and im getting new paint on it plus im a college student. This is my daily driver in the summer, I'm mainly doing this for looks and to help keep the rear end down/handle better on corners. I'm only looking to lower it by 1.5-2". My questions are;
1. Lowering Springs-Would you trust buying the cheaper Ford racing and BBk springs over eibach?
2. Upper and Lower rear control arms-Do I want them to be adjustable?
3. CC plates-Do i need them? Ive heard yes and no.
4. Saving money-I understand you get what you pay for but are some of the less expensive parts/products just as good as the higher priced ones?
5. Am I missing anything I need?
Thank you for your help
http://granatellimotorsports.com/ind...les_type&vid=3
http://granatellimotorsports.com/ima...m-s9604stp.jpg
http://granatellimotorsports.com/pro...et-577-27.html
http://granatellimotorsports.com/pro...ck-316-27.html
Black or Red
http://granatellimotorsports.com/pro...er-126-27.html
http://granatellimotorsports.com/ima...m-ca7998wj.jpg
http://granatellimotorsports.com/pro...ms-124-27.html
I did finally hear back from MM on that issue, and one thing their tech said some people did was to make a bushing or use some electrical tape on the piston rod. I was going to try this eventually, but probably not until I go with a coil over kit.
What CC plates were you using? I will personally vouch that they are noisy with MM CC plates, and even MM agrees with me. I haven't double-checked it yet myself, but MM even offers up a reason why they are so noisy. That's not saying there isn't a fix, but as the Stranges and the MM CCs come from the factory there is a lot of noise.
Matt's 95 Stang
10-05-2015 07:16 AM
