T-3650 question - MustangForums.com
Old 05-26-2013, 08:11 PM   #1
RiCe_KiLlEr
RiCe_KiLlEr's Avatar
Default T-3650 question
hey, i just pulled out my engine and transmission from my 2004 mustang gt. its has a t-3650 transmission and i am trying to separate the transmission from the engine. everywhere i read it says it should just pull apart and i have been trying and i can not separate them. is there a trick to separating the the engine from transmission? theres about an 1/2 gap between the engine and transmission and i can spin the transmission but can't completely separate them. thanks for the help
RiCe_KiLlEr is offline   Reply With Quote
Old 05-26-2013, 08:26 PM   #2
JC316
JC316's Avatar
Quote:
They should just pull right apart. With a 1/2 inch gap, I doubt it's a bolt holding it. Is the shifter handle hitting up top?
JC316 is offline   Reply With Quote
Old 05-26-2013, 08:37 PM   #3
RiCe_KiLlEr
the engine and transmission is out of the car. is there a special way to release the throwout bearing? i don't see whats holding it together
Old 05-27-2013, 01:33 AM   #4
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
user error...if all 13mm bellhousing bolts are out, and the 2 13mm bottom plate bolts are out, it should slide off....try wiggling with 2 pry bars on either side of the "1/2inch gap"
if you fail to do this, you are a complete zilch...
WhiteFoxGT is offline   Reply With Quote
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 09:13 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 09:06 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 11:29 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
