E Brake Help
Old 06-05-2013, 08:19 AM
razor9546
razor9546's Avatar
Default E Brake Help
The other day I pulled up my brake and it felt like I broke it once it was about half way up it sounded like it snapped and had no tension but when I put it back down and pull it up it works fine, but it always loses tension between the first pull up. Wondering if someone can point me in the direction to why its doing that. If it needs adjustment can someone point to the a thread on how to adjust it? I'm on mobile so I don't know where to search sorry to cause an inconvenience.
razor9546 is offline
Old 06-06-2013, 01:10 AM
JC316
JC316's Avatar
There is a hooked arm that presses down on gears to allow you to pull the Ebrake. I am guessing that piece is slipping, or the gears are worn down. It's hard to explain, watch my video and you will see what I am talking about. I talk about it around 2:15.
JC316 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: E Brake Help
