Bad TOB cause occasional Grind?
Old 06-21-2013, 07:08 PM
302_Mustang
302_Mustang's Avatar
Default Bad TOB cause occasional Grind?
Well my TOB on my 2000 Mustang GT with the T-45 just completely went this morning. Before it went the TOB would make a grinding noise and the sound would change whenever I pressed the clutch in. And once every 10 shifts only 5th gear would grind going in. I had to drive home 40 miles with the bad TOB and it didn't grind going in 5th.
Does anybody have a link to how to drop the T-45? Since I work at a Ford Dealership they will charge me around $250 to install the clutch kit but I might be able to bring it in and install the clutch and get help from the Master Techs if I needed it and this could be the golden oppourtunity to prove myself since I'm the new guy haha.
302_Mustang is offline
Old 06-22-2013, 03:02 PM
Seabee1993
Seabee1993's Avatar
It's not difficult with the proper tools, since you'll have it in a shop you off to goo start. 1. Remove mid pipe and starter 2. Drain Trans 3. Remove drive shaft 4. Remove crossmember, ensure you have support with a jack under the Trans after you take that out all you'll have is the motor mounts supporting all the weight 5. With a long ext remove the top two bolts in the bell housing you can let the Trans down a little on the jack to reach these there the two hardest to reach. 6. Lift the jack up a scoch and then remove the rest of the visible bolts and the dust cover bolts on the front side of the bell housing. 7. I suggest getting help with removal of the Trans it doesn't always come right out, the T45 is only 90lbs empty but.
This was all from memory I'm pretty sure I didn't overlook anything but I'm sure that's about it. If you have more questions don't hesitate to ask. Good luck!
Seabee1993 is offline
Old 06-22-2013, 03:37 PM
JC316
JC316's Avatar
Easy job that can be complicated by the exhaust and starter. I can drop the transmission in about 40 minutes on my cobra. Seabee basically got it right, but I recommend taking the shifter out of the transmission. Makes dropping it easier and refilling it easier.
JC316 is offline
Old 06-22-2013, 04:36 PM
Seabee1993
Seabee1993's Avatar
^ thank you!
Old 06-22-2013, 07:01 PM
302_Mustang
Thank you guys for the help, I'm gonna install my offroad h pipe when re assembling and ill try to write up a detailed step by step with picture Gide since I couldn't fine one for a T-45
Old 06-22-2013, 07:41 PM
Seabee1993
Seabee1993's Avatar
Might as well change your clutch while you're in there too.
Old 06-22-2013, 08:30 PM
302_Mustang
That's what I'm doing, got a full ford racing clutch kit on the way.
Old 06-22-2013, 09:40 PM
Seabee1993
Seabee1993's Avatar
I've gotta get mine rebuilt, effing dreading it. I think it's the original with the car.
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Bad TOB cause occasional Grind?
