Intake manifold crack, what to expect? - MustangForums.com
Old 07-01-2013, 09:54 PM   #1
rwdfan
Default Intake manifold crack, what to expect?
Alright, so I'm heading down to go purchase a 99 4.6 GT with a cracked intake manifold. Car dumped radiator fluid all over the place out of the manifold, etc... Car has been sitting for 3 years and was started once a year ago in that period of time. It has 80k miles, other than replacing the intake manifold with a PI model and the 01 up alternator bracket, siphoning the tank, emptying the fuel lines and fuel filter, changing the oil, changing the thermostat, putting in fresh antifreeze, and checking the plugs. Is there anything I should do before starting it, or even check before purchasing? The owner states they were fighting ford to get them to cover it under the recall but that in the long run they said you are 6 months out of the recall warranty and didn't cover it. Advice?
rwdfan is offline   Reply With Quote
Old 07-02-2013, 07:40 AM   #2
xx10Gt
how much are you thinking about potentially spending on this?
xx10Gt is offline   Reply With Quote
Old 07-03-2013, 12:17 AM   #3
rwdfan
Well, they want 3300 for the car. Im figuring 1k for the top to be done, 600 for tires, 300 for the intake , plugs...coils...coolant...thermostat...etc...300?. ..so 2200? 5500 total...
Old 07-03-2013, 01:25 AM   #4
Gt04
Gt04's Avatar
I Have A Spare Intake And 04 Alternator Bracket If You Do Decide To Get It And You're Interested.
Gt04 is offline   Reply With Quote
Old 07-03-2013, 09:13 AM   #5
xx10Gt
i wouldnt go over about 2800 for it imho
Old 07-03-2013, 09:53 AM   #6
school boy
school boy's Avatar
Whoa there chief! what top end change are you talking about?
school boy is offline   Reply With Quote
Old 07-03-2013, 05:14 PM   #7
JC316
JC316's Avatar
You are taking a pretty big gamble that the heads aren't trashed. $3300 is a bit rough on a non running car that has been on the road in 3 years.
JC316 is offline   Reply With Quote
Old 07-03-2013, 09:21 PM   #8
rwdfan
Found out they charged up the battery and tried to start it yesterday. It started right up surprisingly, though they didn't run it for long due to the leakage... Why would the heads be trashed because of a cracked intake manifold?
Aluminum / performance intake 97 GT 4.6 help Vrooom 4.6L General Discussion 13 02-21-2016 06:25 PM
Ticking coming from 4.6L. What could it be? Shadow7874 2005-2014 Mustangs 4 09-24-2015 10:06 PM
Really scary throttle issue, Bullitt tuning or something wrong here. JDWalton 4.6L V8 Technical Discussions 8 09-24-2015 09:47 PM
leak down tes bconboy 2005-2014 Mustangs 6 09-24-2015 02:55 PM
High idle after cleaning Imrc Scottyboy187 SVT Forums 1 09-13-2015 11:23 PM
