Buying a Mustang GT
Old 08-05-2013, 08:45 AM
Shane4.6GT
Shane4.6GT's Avatar
Default Buying a Mustang GT
Hello guys, I first would like to say that I'm new to this forum and very excited about purchasing a 2000 Mustang GT with 139,000 miles on it for $5k.
Also, I 'm new to the mustang world and hope you guys can give me some pointers about some issues i may run into with this much mileage such as, reliability, durability, problems, annoyances, pros and cons.
Thanks.
Shane4.6GT is offline
Old 08-05-2013, 01:14 PM
xx10Gt
xx10Gt's Avatar
Thanks.
these 4.6 modular motors are very nice and strong as long as they were taken care of... do you have a car fax report or something that shows all the maintenance was done at regular intervals?
I would perform some maintenance when you get the car home.. oil change, tranny fluid change, fuel filter, spark plugs, etc
xx10Gt is offline
Old 08-05-2013, 03:09 PM
antwaan
antwaan's Avatar
See what kind of intake manifold it has on it. If its plastic it very well could break.
antwaan is offline
Old 08-07-2013, 09:38 PM
Shane4.6GT
Shane4.6GT's Avatar
Well, I don't have its CarFax. But the clutch was done at around 80000mi, new upgraded intake manifold at 97,000, newer coolant change, newer coil packs, and a newer belt.
Yes, i usually always do a full flush when i buy a second hand vehicle. You just never know what the other owner is running in it.
Old 08-07-2013, 09:39 PM
Shane4.6GT
Shane4.6GT's Avatar
What do you mean?
Old 08-08-2013, 06:14 AM
supersnake67
supersnake67's Avatar
He means that Ford up until the 2001 mid model year I believe had a full plastic intake. Even for the coolant crossover. Which are more prone to cracking. I have an 04' and I have the newer aluminum cross over , but mine cracked about 2 months ago. The plastic under the crossover pipe just fell apart and I had a coolant leak. Good in theory just bad idea.
supersnake67 is offline
Old 08-08-2013, 10:49 AM
school boy
school boy's Avatar
If you have access to a lift, check all moving parts, fluids, bushings, etc. Also check for uneven tire wear. Test drive and go through all the gears, including reverse, and check for odd noises. Make sure all buttons/switches functions. Also take a "negative nancy" with you. They wont be as excited and will nit pick everything.
school boy is offline
Old 08-11-2013, 02:46 PM
Shane4.6GT
Shane4.6GT's Avatar
Interesting, great info. I guess that is why he had replaced the old intake.
Old 08-11-2013, 03:12 PM
Shane4.6GT
Shane4.6GT's Avatar
Thanks will do. This is my first time buying a car and it will be my first car as a college student. So i want to make sure it will last me at least another 5 years or more.
Old 08-12-2013, 06:05 PM
hpwrestler220
hpwrestler220's Avatar
These cars are work horses. Only thing I've had go on mine in the last 5 years has been the fuel pump... Nothing else has really been a problem with this car...
hpwrestler220 is offline
MustangHead91
09-15-2015 09:07 AM
smecla
08-26-2015 10:37 PM
Mr. D
08-17-2015 09:53 PM
robjh22
08-17-2015 07:35 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: Buying a Mustang GT
