Coolant tank LOW..
Coolant tank LOW..
So I can barely see any coolant in the tank, I do see it really low right at where the hose meets the tank tho.... I need to add some but was wondering if I should only add the motorcraft green engine coolant, or, can I just stop by autozone and add Prestone 50/50 green coolant?
Basically....Is it safe to mix diff brand coolants as long as they are both green colored?
Yeah just use the green stuff; 50/50, full strength, whatever. Brand doesn't matter, they will mix fine. For as minimally low as it is though, I would just go spend $2 on a gallon of distilled water instead and pour that in, call it good. Keep an eye on the fluid level for a bit and make sure it isn't being consumed or leaking.
mrappe
09-26-2015 10:16 AM
