Engine ticking - bad lifter?
Just wanted some opinions. First off, apparently my oil gauge doesn't work. About 2 weeks ago, I noticed a ticking noise coming from the bottom of my engine. I checked the oil, the dipstick was bone dry. Got under the car and somehow the drain plug on the oil pan was loose and I was dripping oil. So I changed it (there was about 1.5 qt's left) but it didnt stop the ticking. The ticking generally doesnt start until the car warms up, really loud and obnoxious from 1st to 4th gear, but pretty much goes away in 5th. I think it's a bad lifter, and no it's not an exhaust leak, i already checked for that. Any other opinions?
Why waste 300$ in parts for a spun bearing in the bottom end. If he was running that motor with 1.5qts in it I wouldnt spend another dime on it
Bottom end would be worse case scenario but I've seen people get away with worse situations but its worth a shot u can get a set of adjuster in followers out of the junkyard for like $20 theres am abundence if 4.6 2v in all the crown vics and others.
Well I never attempted to fix it the first time. It just happened lol. But thanks for the advice everyone. Gonna take the valve covers off tomorrow and take a look. I don't think it's a spun bearing. The car drives fine, no loss of power or anything actually. Was kinda hoping it would just blow up so I could collect the insurance money on it.
im just speculating by your original post. you said a ticking from the bottom of the engine. usually valvetrain noise is up top. you may be able to pin-point it easier by using a long screw driver and hold it against your ear. however we cant do anything for you without actually having the car in front of us. i dont want to see you spend money up top end parts if indeed you spun a bearing
Ok so I took the valve covers off and found the problem. The cam chain guide is just loose and rattling around in there. It's like it broke off and it just making a ton of noise. Where should I even start with replacing that? It's on the passenger side of the engine. The driver side is in place and not moving at all.
Going to have to remove the timing cover...
I recommend replacing both guides along with the chain tensioners. Be cautious because the motor could jump time when you remove the tension. Once its replaced, you will have to verify correct timing
