Coolant pooling on block under intake manifold
I have a 02 GT. I just noticed that I've got some coolant pooling on top of the engine block directly under the PI intake Manifold...
Where could this coolant be leaking from? The intake manifold itself? I can provide pics if needed for better explanation...
What are your thoughts on where its leaking from? The car drives fine and the temp gauge has been fine.....
Does this look familiar?
https://mustangforums.com/forum/7943362-post21.html
Mine turned out to be bad head gaskets and a cracked intake manifold.
book time is either 3 or 4 hours for a mod intake. (cant remember) which at my shop is $90/hr. Clean the whole area, bomb it with a ton of water, spray it dry with air, then pressure test the system and look for the leak
